Old 12-12-2011, 09:51 AM   #1
bathroom ventilation
I've have read several comments about never venting a bathroom fan through a soffit. I went to my local hardware store they said it was fine to vent through the soffit if I had the right soffit cover. The one they showed me was louvered and self closing when the fan isn't running. Will this type of soffit cover eliminate moisture re-entering the attic because it's self closing?
LMPD is offline   Reply With Quote
Old 12-12-2011, 10:13 AM   #2
Find another way to vent it. Out the roof or gable if you can.
It really isn't an issue with the exhaust vent.
Do you have soffit vents for your attic?
When the exhaust fan is on, warm air is exhausted under the soffit. Warm air rises. If there is any opening into the attic, the moist air will get in and condense.
The soffit itself will also get wet. Mold and mildew will likely result.
Hope it helps.
AandPDan is offline   Reply With Quote
Old 12-12-2011, 01:49 PM   #3
The bathroom vent exhausts air. The soffit is an intake to ventilate the roof. It is generally not a good idea to put an exhaust and intake side by side in any situation.
shazapple is offline   Reply With Quote
Old 12-12-2011, 02:01 PM   #4
Thanks, I certainly have a better understanding now.
Garage ceiling insulation MNHouseRepair Insulation 16 12-05-2011 03:57 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
BAD ADVICE??? You tell me! Bathroom Exhaust Fan Ventilation firefish317 Plumbing 2 04-20-2010 09:23 PM
Bathroom ventilation / window privacy issue Michael Thomas General Discussion 10 05-26-2009 10:09 AM
Bathroom ventilation and cooling dragon6172 General Discussion 3 05-11-2009 03:40 PM
