Bathroom Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 07:41 PM   #1
Bathroom switches
I have three sets of wires coming into my bathroom wall! One set is newer with a black wire, white, and ground. The other two sets of wires are older and only have one black wire and one white wire each! They were wired to two switches which controlled a vanity light, a bath fan, and another light over the shower. One of the switches was a plug in/switch combo! I have two new switches, but I do not know how to rewire them! The original set up had most of the wires connected to one switch with a piece of wire used as a jumper to power the other switch! If you can understand what I'm saying, then you know my dilemma! Please help! How do I rewire all of this safely?
ryanwm1978 is offline   Reply With Quote
Old 06-23-2011, 08:22 PM   #2
Rewards Points: 6,652
Black from the lights to each switch, whites all tied together with white from the panel. The black from the panel, will need three lengths of wire to allow you to power the bottom screw of the switches, so you have power to the lights & fan.
Old 06-23-2011, 08:41 PM   #3
joed's Avatar
Rewards Points: 13,752
Except he has three light and three cable so there is no power from from the panel. Sounds like three switch loops and the receptacle will not work.
In order to confirm this you need to open up each light fixture and tell us all the connections in them without taking anything apart.
Old 06-23-2011, 08:43 PM   #4
Just caught that, in that case, scratch what I said.
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 10:36 AM
worth it in terms of energy savings to replace bathroom exhaust fans? ChrisJJ Electrical 0 06-14-2011 10:17 AM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
Bathroom light switches Blaze25 Electrical 3 11-13-2006 02:01 PM
