Bathroom Switch And Central Air/Furnace - Electrical - DIY Chatroom Home Improvement Forum
Old 06-17-2014, 03:16 AM   #1
Rewards Points: 506
Bathroom Switch and Central Air/Furnace
Hey all. I've got a bathroom light switch that trips the breaker, and the AC/Furnace goes out. The circuit is 15a. How can this be that the bathroom and AC are on the same circuit?
Installation is the Reverse of Removal.
Old 06-17-2014, 06:44 AM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
First off, find out where the fault is.
The Following User Says Thank You to stickboy1375 For This Useful Post:
sirsparksalot (06-18-2014)
Old 06-17-2014, 07:35 AM   #3
Rewards Points: 338
stickboy is right. First find the problem. The answer to your second question depends on when it was wired (pre-bathroom it's on circuit requirement?) and who did the wiring.
petey_c is offline   Reply With Quote
Old 06-17-2014, 02:11 PM   #4
Rewards Points: 1,832
Either the Furnace and bath are on a double pole breaker, they share the same single pole breaker, or the hots from different circuits are tied together. That would explain both going out at the same time.
Your next step is to repair what ever is short circuiting. If its the switch that does it your fault is pretty much narrowed down to what ever is on that switch.
Jump-start is offline   Reply With Quote
Old 06-18-2014, 07:25 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 150
Could be a gas furnace and just the blower on the same circuit as the bathroom light.
Old 06-18-2014, 04:03 PM   #6
Rewards Points: 506
Thanks, jb, I think this is the case.
Could it also be that the thermostat is on the bath circuit?
Old 06-18-2014, 04:13 PM   #7
PoleCat's Avatar
Rewards Points: 1,646
That is usually the case.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 06-18-2014, 04:40 PM   #8
Rewards Points: 506
I don't really know how A/Cs and furnaces are wired, but I was meaning that perhaps the thermostat was 120v wired, while the A/C was 240v. Is that possible?
Old 06-18-2014, 05:06 PM   #9
Rewards Points: 3,256
Normally they are powered by 24 volts from a power supply in the unit itself.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
sirsparksalot (06-19-2014)
Central Exhaust fan, adding a switch fumbrunner Electrical 2 11-16-2012 01:47 PM
taco sr503-4 switch jmon HVAC 53 11-12-2012 07:26 PM
Analog multimeter shows voltage even with 3-way switch off OCPik4chu Electrical 17 09-25-2012 01:20 PM
Add Third Timer Switch to Central Exhaust Fan MaxSteel Electrical 4 11-01-2011 03:08 PM
Central Air/Furnace Fan Problem crowbb HVAC 17 04-10-2010 09:01 PM
