Bathroom remodel, lighting question
I don't live far from you....so I'm 'somewhat' familiar with the codes.
No, no GFIC for the light. But if over the tub, must be for 'wet locations'....so, yea, you need the new trim.
Assuming your doing this to code, they will want the fan and light on the same switch.
Also....you may be required to make sure your existing outlet is to code....i.e, you're outlet must be feed by a dedicated 20A breaker. It can not be shared with any other outlets in the rest of the house.
I believe you can run your light and fan off the same ckt....but I wouldn't do it.....I don't like putting lights and outlets on the same breaker....if you trip the bathroom breaker, then your lights go out.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
