Bathroom Remodel Issues - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2009, 05:12 PM   #1
Bathroom remodel issues
I am in the process of a complete gut/remodel of my bathroom. House was built in the 20's, there was slight upgrades made in the mid 90's before I got it. The wiring going to the lights and switches is a single wire, with a cloth type jacket. I assume this is series, one wire into the fixture one wire leaving. My question is, do all the new outlets, lights, and floor heat strip, need to be wired the same way? Or can I convert it to a parallel system somehow? With the way it is now, there will be no ground wire to anything. Any input or ideas would be great.Thanks,Brian
Briguy1010 is offline   Reply With Quote
Old 05-09-2009, 06:12 PM   #2
Sounds like you have Knob and Tube wiring. Time to update and rewire.
hayewe farm is offline   Reply With Quote
Old 05-09-2009, 06:26 PM   #3
Agree........most codes do not allow you to add any additional anything to a K&T system. Some don't even allow it to exist when remodel time comes. I agree with the code. K&T wiring is not safe, is too old, is not safe, and it is not safe.
Old 05-09-2009, 08:55 PM   #4
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
Knob and Tube can be extended but I wouldn't suggest doing it if your walls are open and new wiring can be installed. Budget's are budget's and I understand that but taking the cheap way out when it comes to wiring and plumbing is bad, bad idea.
As for Code, it is permissible. 2008 NEC 394.10
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 05-09-2009, 10:06 PM   #5
It is permissible but most people don't know the proper way to splice or the required mounting. If it is done it should be done by a qualified electrician. Any mistake could void insurance coverage if there is a fire. Plus Just because NEC permits it doesn't mean all jurisdictions do.
Old 05-09-2009, 10:30 PM   #6
This is Knob & tube
Does it look like this?
Or is it cloth covered wire with 2 wires in it - no ground ?
That is old NMB
There is also old cloth covered wire with 2 wires & bare ground
Also NMB
Old 05-10-2009, 08:00 PM   #7
It looks just like that. Looking into our options on replacement. Options are few to run new wiring to bathroom....crawl space is small under the floor and space between ceiling and roof is like 10 inches. Thanks for the input everyone
Bathroom Remodel MeraleeCrowl Remodeling 4 01-11-2009 08:28 PM
bathroom issues, renovating DIY help wombosi Plumbing 1 11-04-2008 11:06 PM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 12:04 PM
2nd floor bathroom issues allneedsgurl Plumbing 5 12-10-2007 08:23 PM
Bathroom remodel - need advice sparky472 Remodeling 12 10-22-2007 05:03 PM
