Bathroom Power Switches Relative To Bathtub - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2008, 09:54 PM   #1
Rewards Points: 1,062
Question
bathroom power switches relative to bathtub
does the code specify that the bathroom power switches must be a certain distance away from the shower/bathtub ? mine are planned to be fairly close (a foot from the edge of the tub, horizontally).
Old 10-13-2008, 10:10 PM   #2
Registered User
Termite's Avatar
No, it just prohibits them from being in the wet area.
Receptacles and switches cannot be within the enclosure of the shower or tub. Basically not in an area that is likely to get wet. I would certainly allow either of them 12" horizontally from the edge of the tub or shower floor in most cases.
Here's one interpretation that a local municipality uses to explain this requirement...
If you were to put a glass surround around the shower, the electrical can't occur in it. If the tub has a tub deck like many master bath whirlpool tubs do, you can't have switches or receptacles over it.
This is a very interpretive topic and is subject to the inspector's thoughts and opinion of the installation, somewhat.
Old 10-13-2008, 11:02 PM   #3
Rewards Points: 506
Send a message via AIM to theatretch85
It was my understanding that the switch cannot be reachable while standing in the shower or 30" from the tub edge. I don't know if its different for a glass shower verses a bathtub that doesn't have a glass surround around it. This topic has been discussed on here before, I'd suggest using the search feature on the forum here; its a very useful tool.
theatretch85 is offline   Reply With Quote
Old 10-14-2008, 08:22 AM   #4
Registered User
Termite's Avatar
Nope, there's definately no code-based reach distance requirement for switches and receptacles from bathtubs or showers.
Old 10-14-2008, 12:16 PM   #5
Rewards Points: 506
Sorry this is what I was thinking of:
Didn't realize the 3ft rule did not apply to the surface or recessed mounted switches and lights.
Found the above in the following thread:
Recessed Lighting above shower
Old 10-14-2008, 12:22 PM   #6
Rewards Points: 14
I am in the middle of a remodel and am installing a whirlpool tub.
I ended up placing the two plugs for the jets and heater in the corner of the alcove of the tub. Under the back corner. Is this considered wet zone or is this ok?
Also, since the tub goes on before drywall and backer/tile, how would you go about covering the outlet box (its plastic)? Can I just place the outlets in and put on a cover plate? Does that suffice or do I need to use a different outlet box?
s4alex is offline   Reply With Quote
Old 10-14-2008, 12:44 PM   #7
Registered User
Termite's Avatar
I figured that's the code section you were thinking of. The 3' out/8' up rule applies to hanging electrical luminairs and fixtures such as ceiling fans, chandeliers, track lights, and pole-mounted fixtures. It doesn't apply to ceiling-mounted non-suspended ceiling fixtures or recessed lighting, nor is it applicable to switches, dimmers, timers, or receptacles.
Old 10-14-2008, 03:07 PM   #8
Rewards Points: 83
I have always run this sort of thing out to an external GFCI (not a receptacle, but a hardwired GFCI) through the studs a few feet away on the wall at the same height as a typical receptacle (14" or so). Usually a whirlpool requires a dedicated circuit.
Something like this:
http://www.leviton.com/OA_HTML/ibeCC...&section=11623
Bubbagump is offline   Reply With Quote
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Power circuits under leaky bathtub? Beren Electrical 1 07-23-2007 09:02 AM
Help with bathroom wiring - URGENTLY NEEDED cfonseca Electrical 4 02-16-2007 01:42 AM
Bathroom light switches Blaze25 Electrical 3 11-13-2006 02:01 PM
