Old 05-23-2012, 10:20 AM   #1
bathroom power
I have a downstairs powder room that has it's dedicated 20 amp GFI receptical. I intend to run from there, two new plug ins in my upstairs bathroom.
Do those two new recepticals need any visible indication that they are GFI protected?
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 05-23-2012, 10:31 AM   #2
Licensed electrician
bathroom power
You may want to consider running them from the line side of the first GFI so that if the upstairs were to trip you would not need to go downstairs to reset it. This will require a second GFI upstairs.
No need for labeling.
Old 05-23-2012, 12:31 PM   #3
kevinp22's Avatar
bathroom power
I agree with Jim - wire from the line side, then have the first receptacle in the upstairs bathroom be a GFCI (you would need to purchase and install a new gfci receptacle here since the downstairs one would provide no GFCI protection) and wire the second upstaries bath receptacle on the load side of the first upstairs receptacle
kevinp22 is offline   Reply With Quote
Old 05-23-2012, 12:32 PM   #4
bathroom power
Thank you, I am however a bit unclear on your information. The first and only GFI outlet is in the downstairs bath. Wouldn't the downstream outlets need to be run from the load side to be protected? And if not, where else but at the original GFI would I reset a tripped circuit ?
Warren Zevon
Old 05-23-2012, 12:34 PM   #5
bathroom power
A second GFI would need to be upstairs also.
kevinp22 (05-23-2012)
Old 05-23-2012, 05:51 PM   #6
bathroom power
Got it. Thanks very much for clarification
Warren Zevon
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
Bathroom to Laundry Room to Bathroom bcatanz10 Remodeling 2 10-10-2011 10:45 PM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 10:43 AM
Project adding 3-phase power to a tenant finish project bnharbor Electrical 5 11-11-2010 06:39 AM
all my bathroom outlet don't have power nugentoffer Electrical 9 04-14-2010 10:16 AM
