Bathroom Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 05:01 PM   #1
bathroom outlets
Bathroom plugs --is there a required height above counter tops for electric outlets???
RussP is offline   Reply With Quote
Old 07-08-2012, 05:21 PM   #2
Rewards Points: 6,652
I keep mine at around 48" from finished floor height.
Old 07-08-2012, 07:35 PM   #3
Put it where you see fit, you know how high your counter is. Just make sure you have a GFI if it's under 3' from your sink.
Wirepuller is offline   Reply With Quote
Old 07-08-2012, 07:38 PM   #4
Umm wirepuller, Bathrooms are considered "Wet Zones", and no matter where the outlet is, it MUST be GFCI protected. Even in a powder room, you have to protect the outlet with a GFCI protected circuit.
The Following 2 Users Say Thank You to gregzoll For This Useful Post:
PaliBob (07-16-2012), Wirepuller (07-08-2012)
Old 07-08-2012, 07:40 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
At least one receptacle outlet shall be installed within 3 ft. of the outside edge of each basin, and it must be GFCI protected, and supplied by a 20 amp branch circuit.
Hope that helps.
Old 07-08-2012, 10:18 PM   #6
Master Electrician
Make sure you leave room for the back lip of vanity top. We just did a kitchen and the designer and engineer missed that. Walls were tiled already so their nice industrial kitchen sink now has a 12 inch stainless steel back with squares cut out to allow access to the plugs :D.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-08-2012, 10:25 PM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Standard vanities are 30". Counters are about an inch, and backsplash is about 4". We usually put bathroom outlets at 40" to center.
Be careful, kitchen height bathroom vanities are becoming more and more popular. Those are 36" tall without backspash or countertop.
Also keep in mind where the bottom of your mirror is going to end up. For this reason alone, I like to install the GFI on the side wall.
The Following User Says Thank You to k_buz For This Useful Post:
andrew79 (07-08-2012)
Gfi outlets keep tripping but not constantly INEEDHELPPLZ1 Electrical 22 09-30-2011 08:28 AM
HRV With Bathroom Stale Air Pickup??? 1BadBoy Building & Construction 10 06-17-2011 02:17 PM
1886 Eastlake - add upstairs bathroom or expand downstairs bath?? TOTALN00B Plumbing 1 05-14-2011 09:54 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
Bathroom electrical outlets dontom Electrical 2 01-07-2009 08:11 AM
