Bathroom Outlet Help! - Electrical - DIY Chatroom Home Improvement Forum
Old 05-11-2011, 08:51 PM   #1
I'm new to this board but anyway...
My bathroom outlet only works when the lights are off! When the lights are off it works perfectly and can power my hairdryer and sorts but I would like it to work when the lights are on!
Can anybody give me any advice?
I know I haven't really given to many details but if you ask I will look into it... Sorry I'm not really an electrician
DarkSlayer00001 is offline   Reply With Quote
Old 05-11-2011, 08:52 PM   #2
Learning by Doing
Leah Frances's Avatar
Two questions:
1. Do you know what circuit(s) control(s) the bathroom and how to shut it off?
2. Do you have a non-contact voltage tester?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-11-2011, 08:54 PM   #3
1. Yes I know which how to switch off power to the bathroom
2. I'm pretty sure I have one somewhere but I don't know... I can look
Old 05-11-2011, 08:57 PM   #4
Learning by Doing
Dig out your non-contact voltage tester and probably a camera to take some pics.
I'm not going to be able to help troubleshoot (I'm competent at installation, but not figuring out what-done-gone-wrong), but I can tell you, if you are willing to do some work, post some pics of your set-up, someone here probably will.
Old 05-11-2011, 09:01 PM   #5
How much work? If it's alot I'll just ask my friend to help or hire an electrician
Old 05-11-2011, 09:04 PM   #6
dSilanskas's Avatar
Sounds like you have a loose neutral somewhere. Either the plug is back stabbed and the connections have become loose and or it's somewhere else.
dSilanskas is offline   Reply With Quote
Old 05-11-2011, 09:06 PM   #7
How would I go about dealing with this... Taking out the Outlet and rewiring?
Old 05-11-2011, 09:11 PM   #8
Learning by Doing
Start by asking more questions here. Also, if you decide to pull some switches and outlets take pics as you go and LABEL EVERYTHING so you can put it back how it was.
Old 05-11-2011, 09:28 PM   #9
Electrical Contractor
kbsparky's Avatar
Betcha someone installed a 3-way switch on your lights there. The downstream load of the rest of the circuit is interrupted by the 3-way switch.
I'd start looking there, and replace it with a single pole unit if that is the case.
-KB
Old 05-11-2011, 11:53 PM   #10
Semi-Pro Electro-Geek
Rewards Points: 2,970
Has it always been like this, or is it a new problem that just started happening? If it's always been this way, then I bet KB has it right: someone installed a 3-way switch for the light and connected the downstream devices to the other terminal on the switch for some reason. If this is a new problem, then please describe what occurred when it first happened, and describe the symptoms in as much detail as possible.
mpoulton is offline   Reply With Quote
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
gutting bathroom debiasio Remodeling 30 02-17-2011 02:32 PM
ground bathroom outlet flman Electrical 4 01-16-2011 11:52 AM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 08:00 PM
outlet in bathroom cabinet OK? matty Electrical 5 08-02-2007 09:56 PM
