Bathroom Lights Not Fully Powered - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 04:22 PM   #16
I have a fluke multimeter. I tested the volts coming from the breaker and it is getting 122volts but when i plug it all in and test the lines going to the light it goes to 44 for a second and the slowley drops to 25 then goes back up to 44 or 45. I installed a new 20 amp breaker today and it still does the same. I have the switch that i used before and the new switch and both do the same thing.
tcfls2 is offline   Reply With Quote
Old 03-11-2013, 04:26 PM   #17
The amps also arent getting over 1.5.
Old 03-11-2013, 04:47 PM   #18
Rewards Points: 83
seems to me that you should not be adding a non gfi protected recept in a bathroom. also I fixed a ho wiring job where the two ligbts were wired in series after the switch. had the same dim light symptom because of the increased resistance & voltage drop
mech_gui is offline   Reply With Quote
Old 03-11-2013, 04:58 PM   #19
I found out that the hard way that the ground has power coming through it. I tested it after and it has 120 coming throughit, so i am stopping there and letting someone else re wire it.
Old 03-11-2013, 05:03 PM   #20
Rewards Points: 83
shut the breaker off and call an electrician
Old 03-12-2013, 12:55 PM   #21
I called an electrician and he said to check all the receptacles, because his guess was one of those have a lose common wire. I ended up checking one of the lights and there was a common wire tied in with the hot wires. I got it sorted out and now everything is working great. Thank you for everybody's help.
Old 03-12-2013, 10:46 PM   #22
dmxtothemax's Avatar
Rewards Points: 5,190
It sounds like you have some how ended up with a series
configuration !
This means the wiring is completely wrong.
Put it back the way it was before,
And call an electricain.
dmxtothemax is offline   Reply With Quote
bathroom circuit size..... CharlieR Electrical 14 03-25-2012 02:52 PM
Wiring Scheme for Bathroom Vanity Lights DAKRO Electrical 5 01-17-2012 02:21 PM
Hallway and garage on same circuit - NEC 2005 fuzzball03 Electrical 10 12-13-2011 09:46 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
Solar powered interior lights Kurt1968 Electrical 2 12-01-2009 06:10 PM
