I am in the process of planning the lighting for my bathroom. There are basically two separate areas divided by a wall with a doorway...One side, the shower is 3' x 10' the other area with sinks/bathtub is 5.5' x10'. Both have 7' ceilings Right now my main concern is the 3x10 shower area. the entire area including ceiling will be tiled. Do people typically use recessed lighting in a wet room/shower? Are there special cans that are needed aside from insulation/non-insulation installation? From my bit of research it looks like the trim piece is what keeps the moisture out. Is this correct?
Secondly, what size is best, and why? I have seen mostly 4 and 6 inch lights what are the pros/cons of each?
How many should I have and what should the layout be in each area?
Lastly, for the shower, where we are tiling the ceiling, how much of the recessed can should I leave exposed in the ceiling if any? Are most cans designed so they hang the correct amount down. We currently have the ceiling gutted...it was lathe and plaster now the plaster is gone, and the lathe is still there to hold up the insulation. We will leave the lathe and attach the cement board on top of this. I have access to the attic so I will probably just use new work lights.
Thanks for the suggestions,
Richard
Richard
