Bathroom Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 05-12-2007, 11:46 AM   #1
Bathroom Lighting
just removed the medicine cabinet in my bathroom and am going to replace it with one that does now have a lighted vanity on the top.
I would like to install a new light above the new cabinet. I would want to convert the outlet on the right to an outlet with a switch and 1 place to plug something into.
What would be the best way to go about wiring everything up.
Please note, I am new at this. All I've ever installed is a new light fixture.
Any help?
Buff is offline   Reply With Quote
Old 05-12-2007, 01:43 PM   #2
What did those wires do before you disconnected them?
why did you not cap off all of the ends?
Master Electrician
jwhite is offline   Reply With Quote
Old 05-12-2007, 10:32 PM   #3
I didn't cap them all because I didn't have enough caps to do so.
The wires on the left were connected to a medicine cabinet with a lighted vanity. The wires on the right were connected to the power as well, they connect to the outlet through the wire-track.
Old 05-13-2007, 12:50 AM   #4
Rewards Points: 6,652
Since it is Panduit and an external box, you can pretty much rip it out and toss it if you want. If you want to install a light with switch, your best bet is to change the outlet into a Switch/outlet and use the switch to control the light above the medicine cabinet. This means that you most likely will either have to cut a hole into the wall for the cabinet (makes for easy electrical install), or place it on the wall, cut a hole smaller then the cabinet to allow access to the internal wall structure, and then do the electrical work.
Your job is much easier then you think.
Old 05-13-2007, 05:11 AM   #5
It looks like you are saying that the wires on the left are the feed for the bath. The old vanity had a built in switch, and the wires on the right feed the GFI recepticle.
You will not have an easy time finding a GFI/sw device. It may be best to turn the existing gfi box into a two gang box. If you are willing to do some drywall work, now is the time to fish everything inside the walls and make it look cleaner. You may even be able to hide all the drywall damage behnd the new cabinet.
Master Electrician
Old 05-13-2007, 09:46 AM   #6
The wall is not drywall, it is some sort of wood partical board.
Light above cabinet attached to the wires on the left. switch/outlet connected to the power attached to the light.
Can't be that hard?
Old 05-13-2007, 11:01 AM   #7
It is not that hard. Most likely the panel is Masonite, which is easy to work with if you have the right tools (RotoZip or Dremel with cutting bit), and make a small enough hole where the cabinet will be, so you can fish everything that you need to.
If you can, you may be able to pull new wire to be able to run 12/2 to make a grounded connection, which is what a GCFI outlet should be connected to.
Old 05-13-2007, 12:24 PM   #8
Electrician
Rewards Points: 794
Yup what you have in that picture will work except it will be illegal and against the electrical code. A plug in the bathroom has to be a GFI and the plug in your picture is not a GFI. Now if this plug is feed from another GFI it will be legal, test the other GFI to confirm it will turn off that plug in your bathroom.
If I were you I would cut into a wall with a two gang box and put the GFI one one side and the switch in another.
If your not willing to do the extra work and do it properly by installing a GFI please don't ask for anymore advice, no one on here wants to be responible when someone dies from your installtion.
BTW Greg a gfi does not need a ground. A GFI is a code compliant way of putting a 3 prong plug in where there is no ground.
darren is offline   Reply With Quote
Old 05-13-2007, 12:29 PM   #9
a new gfi circuit needs a ground. the other is for retrofit and does not count if you are running new wires.
If this rec were per chance feed from another gfi, then I have to ask from where? this rec must either be on a rec circuit that only feeds bath recs, or each bath must be on its own lighting/rec circuit.
Master Electrician
Old 05-14-2007, 02:18 AM   #10
Well I don't really know what I am doing, that's why I'm asking.
Do they make GFI switches like the one I want? I am willing to add another box for the switch if I have to.
How would it all be wired if I added another switch?
I want to do things the right/safe way. Like I said, I am new at this and basically need baby steps to get me to where I need to be.
Old 05-14-2007, 03:17 PM   #11
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
First off, if all you had were three wire caps, you'd likely be better off capping the two black wires and leaving one of the whites. Taping could have been as well. It would be a nice precaution.
I still it think it is a little ambiguous how it was wired. The wire on the right could have brought in power, pigtailed to supply the switched vanity and continued on to the GFCI. Also, the GFCI might be fed from inside the wall and as an after thought that source was tapped to power the lighted vainit, wires run through the raceway pigtail to the vanity and the circuit continues somewhere via the wires on the left.
Have you tested the wires there now to see which ones provide power?
J187 is offline   Reply With Quote
Old 05-15-2007, 11:49 AM   #12
I have taken apart the box and know for a fact that the outlet is wired through the track and into the wires on the left.
The picture was taken a while ago and all of the wires were capped off later that night when I got more caps.
Old 05-15-2007, 03:36 PM   #13
J187's Avatar
Rewards Points: 516
Meaning that there are no other wires entering the box on the wall, just those that from the track? So the wires on the left are the only wires that show power?
Old 05-15-2007, 03:54 PM   #14
So you want to add a switch that controls the new light over the vanity, right?
I'll tell you how I'd do it, and the electricians can check my work.
Add a double box in the wall where the switch will be. Add a box where the light fixture will be. Fish three-conductor cable (12 or 14 depending on whether this is a 20 or 15A circuit) from the double box up to light fixture. Connect the white from the existing 2-conductor wire to the light fixture white, and to the white of the new 3-conductor cable. Connect the black of the 2-conductor to the black of the 3-conductor. Connect the red to the black lead from the light fixture.
In the double box (switch box), connect the black and red to the two screws on the switch. Also pigtail the black to the gold screw on the GFI receptacle. Connect the white to the silver screw on the GFI.
Connect the bare copper ground to the boxes (if metal), to the green screw on the GFI, and to the green screw on your light fixture.
Nate
NateHanson is offline   Reply With Quote
Old 05-15-2007, 05:50 PM   #15
Correct.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Second level / attic bathroom size moneymgmt General DIY Discussions 2 05-02-2007 07:32 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
