Bathroom Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 09-07-2010, 07:59 PM   #1
bathroom lighting
I have a set of light switches that keep tripping the breaker...I have all the neutrals together, grounds together and pigtailed, feed wire with one wire daisy chained to all four switches...black wire from each light tied into switch.
mainiac176 is offline   Reply With Quote
Old 09-07-2010, 09:02 PM   #2
Did you wire everything ?
Is everything on the same circuit ?
Are they all just reg switches - not 3-ways etc ?
I'd disconnect everything & connect one by one & test to see which trips it
Old 09-07-2010, 09:05 PM   #3
Licensed electrician
Rewards Points: 1,024
Sounds like you wired it correctly. I would look for something touching something it should not. Does it trip as soon as you turn the breaker on or when you flip one of the switches?
adding can lighting and bathroom exhaust fan to aluminum wired house matjam68 Electrical 2 03-22-2010 11:50 AM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
Bathroom lighting on GFCI? TReally Electrical 7 10-22-2009 12:05 AM
Bathroom remodel - lighting over shower / water line s4alex Electrical 15 10-10-2008 02:15 AM
Bathroom Recessed Lighting Pineapple Electrical 6 03-03-2008 08:51 PM
