Bathroom Lightbar - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2009, 03:46 PM   #1
eric meadows
Question
bathroom lightbar
a simple lightbar installation only to keep kicking my breaker. I am installing a pull chain switch just like the one i used before, white on white, black on black, ground to ground. hook it together, re-ser breaker, go to the bathroom, lights on, turn light off, turn back on, kicks the breaker again. took lightbar apart to see if any exposed wires but looks good, nothing loose. help!!!
eric meadows is offline   Reply With Quote
Old 08-09-2009, 05:25 PM   #2
dSilanskas's Avatar
I have not seen a pull chain set up that way. Usually you put the black from the power to one lead on the pull chain and you put the black from the light bar on the other lead from the pull chain. Whites just splice together. Try that
dSilanskas is offline   Reply With Quote
Old 08-09-2009, 05:55 PM   #3
"Mystery" of "Shorted" p.c. switch tripping breaker
As poster # 2, Disi... pointed out. You connected the pull chain switch "Across" the leads. Therefore, when the pull chain switch is OFF the light works. But when you pull it to the ON position, you are "Shorting" the leads. Follow their advice and you';ll be A Okay!(Now more than ever)Don't Drink and Drive!!!
spark plug is offline   Reply With Quote
Old 08-09-2009, 08:32 PM   #4
eric meadows
Talking
lightbar
Thanks guys, i will try it. Thanks again.
Old 08-09-2009, 09:50 PM   #5
If so, your pull chain switch is ruined.
Basement bathroom rough in efrobert Plumbing 2 06-23-2011 04:54 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 11:43 AM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 11:04 AM
