Bathroom Light Voltage Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 07:11 PM   #1
Bathroom light voltage problem
Hi, bathroom light went, thought it was bulb, when new bulb didnt work, checked wiring, wires all frayed, trimmed wires and reconnected, now instead of 220v I'm getting 25v.
Anyone know what could be the problem here
Bero is offline   Reply With Quote
Old 01-24-2011, 08:22 PM   #2
Rewards Points: 1,448
A neutral wire may be loose somewhere in your house (or maybe at the electric panel). Do all the other lights in the house work properly? Does this 25 volts change depending on what other lights and appliances are turned on?
AllanJ is online now   Reply With Quote
Old 01-24-2011, 09:03 PM   #3
joed's Avatar
Rewards Points: 12,016
What kind of light is this that requires 220 volts?
Could be bad connection, tripped breaker? The 25 volts might be a false reading if you are using a digital meter.
Old 01-24-2011, 09:11 PM   #4
Electrical Supplier
Rewards Points: 150
Change your batteries on your meter and check on a KNOWN LIVE circuit.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 01-25-2011, 03:44 PM   #5
All other lights are ok, appliances all ok, breakers all ok. Wire was frayed and damaged, repaired now.
I'm in Ireland all mains lights are 220v.
Meter is ok, have used it ok on other tests.
Old 01-25-2011, 04:02 PM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,902
Is this a digital meter? Try measuring the voltage while the bulb is installed - I'll bet it drops to zero. The voltage reading you are getting is most likely a "phantom" voltage - that happens sometimes with digital meters.
Check all your connections carefully. There's probably a bad one there somewhere.
mpoulton is offline   Reply With Quote
Old 01-25-2011, 08:18 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,106
You must have a bad connecttion some were,
Or perhaps a faulty cable.
Work backwards from the light,
Use a known good volt meter,
Check at lamp sockets first.
Next check at switch.
Then sub panel / fuse,
You will soon find were the problem is.
Please be really careful 220v is deadly,
If you dont feel confident you can do it safely,
then dont do it. Call an electricain.
May I sugest you turn of power,
then instal meter,
then turn on breifily to check meter.
dmxtothemax is offline   Reply With Quote
Help! Need way to locate low voltage light cables Johnboy555 Electrical 17 01-13-2017 02:34 PM
Bathroom light placement problem VandalayNH Electrical 2 12-02-2010 10:09 AM
Blinking low voltage light nickdu Electrical 11 11-09-2009 10:09 PM
Off-kilter light fixture in bathroom bungalowgirl Electrical 12 03-16-2009 08:28 PM
Another motion sensing light problem Steelhead Electrical 6 12-24-2008 10:50 AM
