Bathroom Light Stays On Constantly!! - Electrical - DIY Chatroom Home Improvement Forum
Old 05-10-2012, 08:11 AM   #1
bathroom light stays on constantly!!
I am installing a decora double rocker switch (single pole) to control new bathroom lights and a new fan. Nothing fancy, no dimmers, night lights etc...I just want simple "On and Off".
I have a power source, white, black & ground
new wiring for fan white, black & ground
new wiring for lights white, black and ground as well
the neutrals are all tied together and capped off, ground is installed to the green ground screw on the bottom of the switch
the top switch is for the lights and the bottom is for the fan, ok so far so good.
the hot is connected to the top right (black screw)
the other 2 black wires are connected to their designated "legs"
top gold screw for the light and the bottom gold screw for the fan
when I turn the power back on, everything worked, but......the bottom rocker switch turns the fan on and off as its supposed to, but the top rocker switch doesnt do any thing. The bathroom lights are constantly powered!!
I thought it was a bad switch, went out and got another one. same thing!!!
Any help would be great
chischerer is offline   Reply With Quote
Old 05-10-2012, 08:25 AM   #2
joed's Avatar
Rewards Points: 11,516
You have the switch wired wrong. Post a make and model number or an image of the switch.
Old 05-10-2012, 08:28 AM   #3
I will do that when I return home. I will also try to upload photos as well
Old 05-10-2012, 08:34 AM   #4
I found a picture of the switch. I think it is a basic standard basic Leviton/Decora double rocker single pole. Hope this helps.
Old 05-10-2012, 08:36 AM   #5
Missouri Bound's Avatar
The 2 terminals closest together should share the feed, left side of your picture. Then the two right terminals top and bottom should be for the light and fan....one for each. I'm assuming your power comes from the switch box...is that correct?
Do you want it your way or the right way?
Old 05-10-2012, 08:40 AM   #6
Power is comming in from top of the switch box.
light connected to top left
fan connected to bottom left
incomming power source connected to the top right
ground connected to green bottom right
3 neutrals tied together & capped in box.
wow a photo makes it so much easier!
Old 05-10-2012, 08:45 AM   #7
Right....and it doesn't work right with those connections?
Old 05-10-2012, 08:57 AM   #8
The fan portion works fine, turns on and off as its intended to (bottom rocker). The top switch is constantly powered and the top rocker doesn't do anything. The lights just stay on!
Old 05-10-2012, 09:01 AM   #9
Well IF you have it wired correctly,it's a bad switch. I"m not questioning your ability, just sayin'
Old 05-10-2012, 09:10 AM   #10
Already ran out to Home Depot last night to buy a replacement switch thinkin' the same thing. No change.
Old 05-10-2012, 09:28 AM   #11
Licensed Pro
Incoming power goes to the gold screws, power to each fixture goes to the black screws. You have it wired incorrectly.
The Following User Says Thank You to HouseHelper For This Useful Post:
Missouri Bound (05-10-2012)
Old 05-10-2012, 09:32 AM   #12
dogris's Avatar
Originally Posted by chischerer View Post
Power is coming in from top of the switch box.
incoming power source connected to the top right
Unless I am misunderstanding, your lefts and rights are swapped?
I see HouseHelper figured it out before I could finish posting. I am slow!
dogris is offline   Reply With Quote
Old 05-10-2012, 09:52 AM   #13
OMG! We had it hooked up originally that way!!! The jerk at Home depot said to do it the other way!!
Old 05-10-2012, 09:59 AM   #14
Licensed Pro
Lesson learned!
Old 05-10-2012, 10:08 AM   #15
What a surprise.........
Wiring for replacing a bathroom fan, heater, light and night light unit. tgallopbs Electrical 24 11-02-2010 10:57 AM
Replacing Bathroom Light with Fan quinten Electrical 5 10-29-2010 09:25 PM
Electrical bathroom vanity light fixture HEMMY1244 Electrical 4 09-29-2010 08:40 PM
Replacing Bathroom Light Fixtures, going from one to two. diynewb Electrical 3 11-25-2008 11:16 AM
Bathroom light with outlet in it? Jaded Electrical 12 04-15-2008 01:08 AM
