Bathroom Light With Outlet In It? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2008, 05:51 PM   #1
Bathroom light with outlet in it?
I just had to have a new light bar in my bathroom. There are 2 lights in my bathroom, the one I am trying to replace with the outlet in it, and one single bulb light in the ceiling, two switches on the wall, one for each light. We took the old light off and I have 2 white, 2 black and a copper ground. We put white to white, black to black and the ceiling light does not work at all, the new light fixture was on, but would not shut off. We moved stuff around, and the circuit popped off, cuz it was not happy. Now my husband is not speaking to me and told me call an electrician. As of now I have NO lights at all and wires hanging out of the wall (capped of course) .. we gave up. HELP
Jaded is offline   Reply With Quote
Old 04-13-2008, 06:04 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Originally Posted by Jaded View Post
Now my husband ** ** ******** ** ** *** told me call an electrician.
Your husband is a very intelligent man.
Speedy Petey is online now   Reply With Quote
Old 04-13-2008, 06:06 PM   #3
I was hoping I could get help and not have to pay an electrician that would make him happy..
Old 04-13-2008, 06:30 PM   #4
Originally Posted by Joba Fett View Post
Your husband is totally correct. Call the electrician.
Oh alright.... if you guys say so. Our house is older and everytime we try to do something it all goes wrong. The wiring is scary at best, and grounding seems to be optional around here.
Old 04-13-2008, 06:35 PM   #5
joed's Avatar
Rewards Points: 12,872
Do you have any way to test for power?
Try this. Connect the light across the two wires form one cable turn on the breaker and tell us what happens. Then try the same test with the other set of wires.
Also tell us if anything else doesn't work with the wires disconnected.
Old 04-13-2008, 07:03 PM   #6
Yet you want us to help you cobble this thing back together?
Sorry, I gave the only advice I am comfortable with.
Old 04-13-2008, 07:13 PM   #7
Well the wiring is good, the power is there, we just could not get the connections right and I though the GFI wire from the old light may have been a factor. I though this was a place to come for help, I guess not.
Old 04-13-2008, 07:24 PM   #8
Yeah, throw that old line out when things don't go your way.
Typical.
Stick around for a while and read. You'll see this IS the place to come for help. Free help at that!
I'm sure if you go around to enough forums you'll find someone to tell you exactly what you want to hear.
Sorry if I am in a bad mood but crap like this bothers me.
Old 04-14-2008, 11:54 AM   #9
The solution is simple but you need to describe the wiring in detail. Pics are awesome.
Why don't people just LOOK at the wiring before they disconnect
220/221 is offline   Reply With Quote
Old 04-14-2008, 01:37 PM   #10
joed's Avatar
Normally if they would simply use the same two wires as the old fixture it would work. Why they take apart everything is beyond me.
In this case however there is a receptacle in the old fixture so that would confuse how to connect the new one which doesn't have a receptacle.
Old 04-14-2008, 07:07 PM   #11
no need to say sorry, it's Monday now and I still have no lights in the bathroom so my mood is not so hot now either.. Electrician could not come today..
Old 04-14-2008, 07:09 PM   #12
We did.. and it's a mess... with extra stuff we don't need.. brown wires, green wires all attached to the original light... now gone.. left me 2 black 2 white and ground.. I'm off to turn off the breaker and give it another go.
Old 04-15-2008, 12:08 AM   #13
You need a tester to identify the "hot" black wire.
After that it's simple.
Hot black to white (in the other cable).
Remaining black and white go to fixture B&W
Greens/bares go together for grounding.
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 09:46 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
replacing vanity light...issue with outlet box? tarheelblue Electrical 5 01-28-2008 09:20 AM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 06:25 PM
Outlet and light pigtailed to power. ok? skellies Electrical 2 06-24-2006 01:08 PM
