Bathroom Light Fixtures - Electrical - DIY Chatroom Home Improvement Forum
Old 07-02-2012, 06:16 PM   #1
Unhappy
Bathroom light fixtures
The wall mounted light fixtures in both bathrooms were attractive for 6 years, but now have corrosion or rust on them, and the bulb sockets are loose! One bulb is rusted into the socket and will not be unscrewed. Does any manuf have a line of GOOD, moisture-resistant light fixtures that will not corrode or rust out in high humidity, as in near the SHOWER?
Please, no Lowes or Home Depot suggestions, I've boycotted both.
Ol Rick
ol rick is offline   Reply With Quote
Old 07-02-2012, 06:35 PM   #2
Renovations contractor
Bonzai's Avatar
Do you have adequate ventilation in the room ie. is the ceiling fan correctly rated for the size of room?
Just how close to the shower are we talking in regards to the problem lights?
Do you have a lighting specialist store near you? Are you looking for traditional, contemporary or what? There are literally 1000's of different lighting options in part depending on the style you want as well as your budget and what is available in your location.
A few better quality lighting companies:
Artcraft
Quoizel
Kichler
Murray Feiss
Hubbardton Forge
Just to name a few.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
The Following User Says Thank You to Bonzai For This Useful Post:
ol rick (07-24-2012)
Old 07-04-2012, 09:22 AM   #3
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
I would first focus on your humidity problem. Buying a more expensive fixture may not make any difference.
You talked about the lamp being corroded into the lamp socket. There's not a whole lot of difference in the metal used to make that socket from fixture to fixture. The corrosion is occurring because of the high humidity.
Either resolve the humidity issue or look for a fixture rated for high humidity.
JulieMor is offline   Reply With Quote
The Following User Says Thank You to JulieMor For This Useful Post:
Tags
batch , light fixtures , moisture resistant
Bathroom vanity light - mount to single switch box? bsims Electrical 5 08-31-2011 09:57 AM
Wiring for replacing a bathroom fan, heater, light and night light unit. tgallopbs Electrical 24 11-02-2010 10:57 AM
how to wire fan separately from bathroom light? petev Electrical 4 03-27-2010 12:43 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 07:25 PM
