Bathroom Light Fixture- No Stud 1" To Work With!! - Electrical - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 08:20 AM   #1
Bathroom light fixture- No Stud 1" to work with!!
This is from a new house that we are just replacing the light fixture with a modern one. The builder attached the old junction box with one screw at a 45 degree angle for the old fixture.
There is 2 pipes directly behind it. about 1" clearance
Need help with a junction box that can attach directly to the wall that is small enough to fit in front of those pipes.
Also is this a building code issue? Unclear on if you can attach a fixture that way and pass inspection.
see photos
Please help!
Gabe
Bathroom light fixture- No Stud 1" to work with!!-photo.jpg   Bathroom light fixture- No Stud 1" to work with!!-photo-2-.jpg   Bathroom light fixture- No Stud 1" to work with!!-photo-3-.jpg
gmedeiros22 is offline   Reply With Quote
Old 10-08-2010, 01:06 PM   #2
Rewards Points: 3,130
Not a pro, but here's what I would do: Scab two or three small pieces of 1-inch lumber on top of each other onto the stud. Then you'll have room to mount the box through one of the holes in the back of it.
Old 10-09-2010, 11:39 PM   #3
Put a 1x4x2' thru the hole and secure to the sheetrock, then mount the pancake (round box that you took out) to the 1x4, it will be just fine, had to do that plenty of times in bathrooms. Those pipes can be a pain
jddavis is offline   Reply With Quote
Old 10-10-2010, 05:54 AM   #4
Chicago, IL
Michael Thomas's Avatar
If anything other than a single 14/2 cable is entering that box it will be overfilled per code. You may also want to consider if you will be able to provide an adequately secure connection of the box to the ceiling.
Depending on the space available, and perhaps if you are willing to move over a joist, you may be able to use Waco 7120 "saddle box":
which provides 12.5 cu/in. and can securely mount heavy light fixtures and even many ceiling fans.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Ceiling fan light fixture doesn't work c4hfam Electrical 9 03-05-2011 01:01 PM
Bathroom light on a gfi circuit Debbo Electrical 1 04-28-2010 09:32 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
Light fixture issue baustin Electrical 4 07-17-2007 04:01 AM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 08:43 PM
