Old 03-05-2011, 01:56 PM   #1
Bathroom Light fixture installed?
I just replaced the single light fixture over our bathroom sink with 2 separate fixtures, one over each sink. I ran the wire out to one of the light boxes, and connected it there to a new wire out to the other box, as well as to the light over that sink.
Is this an acceptable method of splitting the wire? It seems a little tight behind that one fixture. Should I instead reopen the wall and install a junction box and run the wire out to each fixture from the jbox?
Thanks.
Mike
Mishap is offline   Reply With Quote
Old 03-05-2011, 02:05 PM   #2
Licensed electrician
You can reroute the original cable into one of the boxes and then jumper to the other fixture or use the existing box and drop a cable out to each fixture.
Either way the boxes need to be properly sized for the number of conductors. The splice box cannot be buried in the wall and must remain permanently accessible.
Old 03-05-2011, 02:10 PM   #3
That's what I did, the new box had access for up to 4 conductors, thanks for the quick response.
New Light Fixture won't turn off Aubullion Electrical 4 02-22-2011 01:23 AM
Three light fixture only one light works jenwoode Electrical 1 09-21-2010 01:08 PM
New Member, New House Owner, New Light fixture kingston73 Electrical 3 09-19-2010 07:13 PM
Bathroom Light Fixture with no junction box? shadowman Electrical 2 07-13-2010 07:54 AM
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 10:26 PM
