Bathroom Light Fixture-ground Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2012, 12:07 PM   #1
Bathroom light fixture-ground wire?
I am trying to remove my light fixture. Is this green wire the ground? How do I remove it? Also-when I go to install my new fixture it says to mount it on the outlet box which I don't appear to have. Do I buy this seperatly?
I have attached a pic and will post another shortly. Thank you for any help!
Abber is offline   Reply With Quote
Old 11-11-2012, 12:13 PM   #2
DIY Enthusiast
sublime2's Avatar
The green wire from the old/new fixture should be attached to the bare ground wire. They are likely wrapped together and capped inside The box. That metal box IS your outlet box.
sublime2 is offline   Reply With Quote
Old 11-11-2012, 02:00 PM   #3
Licensed electrician
Rewards Points: 1,028
You could clip the old ground off the fixture and splice it to the new ground.
Old 11-11-2012, 09:24 PM   #4
" Euro " electrician
frenchelectrican's Avatar
You have one issue allready which I can see on the right side of the junction box is the NM cable is fished top of the junction box that need to be addressed.
Second thing look like the junction box is just about over crowed so you will need a larger junction box there.
Merci,
Marc
ground wire for outdoor fixture kingdomfirst1 Electrical 1 02-11-2012 07:24 PM
Help needed: replacing bathroom fan/light & switches. bkboggy Electrical 12 12-28-2011 11:07 PM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
Off-kilter light fixture in bathroom bungalowgirl Electrical 12 03-16-2009 08:28 PM
Stobe light ground wire getting hot! kaliyg Electrical 3 08-21-2008 10:27 PM
