Bathroom Light/fan Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-14-2013, 05:25 PM   #1
bathroom light/fan switch
i attempted to replace an old light/fan switch in my bathroom. I connected it exactly the way it was previously, but the fan will not shut off. I switched the connections around and it is still the same. There is a red wire and two black. anyway, i give up and wonder if there is a way I can disable the black wire to the fan and just not use my fan. I have no money to pay an electrician right now.
jeanelain is offline   Reply With Quote
Old 08-14-2013, 05:45 PM   #2
Licensed electrician
Rewards Points: 1,622
The switch should have a wiring diagram on the package. You need to figure out which wire is the constant hot. It is probably the one not in the same cable as the red.
Old 08-14-2013, 06:24 PM   #3
is there a way to just disconnect the one black electric wire and not use the fan. can i just wrap electrical tape over the end of the wire? I know i can't just leave it unscrewed and hanging out there. obviously i'm limited in this area... Even if I could figure out which is a constant hot, i don't what to do about it.
Old 08-14-2013, 07:22 PM   #4
The constant hot feeds power into the switch. The other two are switched hots.
You should leave the fan operable so hte moisture can be removed from the bathroom.
Old 08-14-2013, 07:28 PM   #5
Rewards Points: 582
get a voltage tester test for the hot leg.....this is the one that will go to the switches...one for fan one for light...other legs to other side of switches...should fix your problem...ben sr
Old 08-14-2013, 08:31 PM   #6
Resi EC
Rewards Points: 252
Turn power off, take one of the black wires off make sure it's not touching anything.
Turn power back on, turn the switch on.
Does the light work? If yes, turn the power off, the black wire that is hanging loose needs to be tied with the red on the switch. turn power on
If it does not work, turn power off, the black wire on the switch needs tied with the red on the switch, the black wire hanging loose is the feed (hot) wire, put it on the opposite side of the other black and red. turn power on
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 04:22 PM
Wiring help for a timer switch (for bathroom exhaust fan)! vanny Electrical 12 07-10-2012 08:58 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 10:57 PM
replacing light switch in bathroom cooper Electrical 3 02-22-2007 05:05 AM
