Bathroom Light/fan On 14/2 With Two Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 02:29 PM   #1
Bathroom light/fan on 14/2 with two switches
I had an existing bathroom light and fan that was controlled independently by two switches. The fan went bad, so I am replacing it. I got up to the attic, and found that the only wire coming into the unit was a single 14/2 wire. How is this possible? Did they make both legs hot and use the ground as a neutral? Unfortunately, this unit was very old, and if it had color or markings on the wires inside the unit at any point, it was no longer visible (they all look white and grey to me), so I am a little fuzzy on what was connected to what inside the box.
slaphappy is offline   Reply With Quote
Old 03-02-2013, 02:32 PM   #2
That's not possible. Unless someone was stupid enough to use the ground as a neutral. If so, rewire it properly with either one switch or add a new wire.
Sparky8370 is offline   Reply With Quote
Old 03-02-2013, 03:27 PM   #3
Rewards Points: 2,516
Were the fan and light all part of one unit? Also for reference see below
Bathroom light/fan on 14/2 with two switches-romex-vs-wire.jpg
hammerlane is offline   Reply With Quote
Old 03-02-2013, 03:30 PM   #4
Yes, one unit.
Old 03-02-2013, 03:38 PM   #5
What is the bare ground of the cable hooked up to??
Old 03-02-2013, 03:40 PM   #6
Well, nothing now. But when I took the unit out, I'm pretty sure it was only connected to another ground inside the unit. Since I didn't take a picture, I'm not 100% certain about that.
Old 03-02-2013, 05:59 PM   #7
Confirmed, they used the ground as their neutral. Crap. Was that ever considered "acceptable"? This house was built in 1981, although, I doubt this light/fan unit is that old. I'm guessing this was just laziness by whoever installed it.
Old 03-02-2013, 08:11 PM   #8
Electrical Enthusiast
Rewards Points: 504
I don't think that type of situation would have ever been legal.
Probably they wanted to install both a light and fan and didn't want to run a new cable.
Kyle_in_rure is offline   Reply With Quote
Old 03-02-2013, 08:16 PM   #9
Yep, and since they didn't want to, now I have to. It's not in the worst spot, but it's still kind of a PITA.
Troubleshooting 3 switches in one box for bathroom project Jerrys84 Electrical 11 08-01-2012 02:48 PM
help, new wiring for bathroom remodel DIYAUSTIN Electrical 8 06-19-2012 07:45 PM
1886 Eastlake - add upstairs bathroom or expand downstairs bath?? TOTALN00B Plumbing 1 05-14-2011 09:54 PM
Bathroom Light & Fan Switches ryanf77 Electrical 2 04-26-2011 08:52 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 10:57 PM
