Bathroom Light Bar Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 03-04-2007, 11:48 AM   #1
bathroom light bar wiring
I am not an electrician, so I have a simple question to have answered. I am in the process of changing out my existing light bar in my bathroom. I have a double sink bathroom with a vanity light installed overhead between the 2 sinks, and is controlled by a light switch on the wall.
What I would like to do is purchase 2 separate vanity lights to install over each sink. Would I be able to take current electrical wiring that is used for the current vanity light and connect 2 sets of electrical wiring from above the sink? Basically, I just want to split it so I can connect 2 vanity light fixtures to it. I want to make sure I am not posing some sort of electrical/fire hazard by doing this.
kenny11876 is offline   Reply With Quote
Old 03-04-2007, 12:34 PM   #2
How many lights per fixture?
redline is offline   Reply With Quote
Old 03-04-2007, 07:08 PM   #3
The original has 12 lights, and the 2 new fixtures will probably have 3-4 lights each.
Old 03-05-2007, 07:25 AM   #4
Does this circuit supply power to other outlets/lights?
Old 03-05-2007, 10:41 AM   #5
The light switch controls only this fixture.
Old 03-05-2007, 03:38 PM   #6
I think you have two challenge:
one is : do you want the separated lights to be on/off at the same time, if not, it would be more difficult
second is: you probably need to move the light position from center to left and right... that means breaking drywall and patching up...
the electricity connection itself if answer to one is No is very straight forward and I don't think load will be that much an issue as most circuit have left over load to be used... but you should check first by turning off your panel switch and see how many devices are off...
KUIPORNG is offline   Reply With Quote
Old 03-05-2007, 06:25 PM   #7
load should not be a problem, since the OP is reducing the circuit by 4 bulbs.
the electric should be easy, but the drywall work will not.
Master Electrician
jwhite is offline   Reply With Quote
Replacing Bathroom Light Fixture shapeshifter Electrical 1 02-05-2007 04:33 PM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
light fixture wiring jasjks Electrical 4 11-29-2006 02:51 PM
wiring a light Unregistered Electrical 6 01-08-2005 09:19 PM
wiring a new light ugmr10 Electrical 2 12-30-2003 10:59 PM
