Bathroom Gutted Redoing Electic - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2009, 07:09 AM   #1
Rewards Points: 150
bathroom gutted redoing electic
Hey, just a quick question
I have my bathroom gutted and im going to redo the electric tonight. The bathroom right now is shared with the bedroom, basement and garage I dont know why but previous owner did that. Since I am redoing the electric these were my plans.
changing the switch to a dual switch. One will turn on/off the exhaust fan. The other will turn on the vanity lights on each side of the mirror along with the tub/shower light.
For the recessed tub/shower light, I will be getting it from my local home center that specifies shower trim. any recommendations on this?
Then the gfci outlet by the door.
fabian is offline   Reply With Quote
Old 01-22-2009, 08:10 AM   #2
Registered User
Termite's Avatar
Sounds fine. Be aware since you're rewiring the bathroom, there are code requirements. The GFCI receptacle either has to be on its own circuit or it can be on the circuit serving the remainder of the bathroom, but if it is combined with the rest of the bathroom that circuit cannot include anything else anywhere in the house (bedroom, hall, etc).
You're correct, you do need a shower trim for the can over the shower. It'll have a removable lens that keeps water from getting up there.
Old 01-22-2009, 08:11 AM   #3
joed's Avatar
Rewards Points: 12,924
Bathroom receptacle must be a 20 amp circuit as well.
Old 01-22-2009, 08:32 AM   #4
Rewards Points: 150
ok so your saying that i should just have the bathroom on its own circuit and has to be a 20 amp. should i get gfci outlets or just do a gfci breaker? your recommendations would be to run a homerun right to the panel correct without having it shared with any other rooms right? the problem is that i have only a 100 amp
Old 01-22-2009, 10:23 AM   #5
Rewards Points: 1,910
Yes, it's own 20 amp circuit. Use a GFCI outlet so that if it trips you don't have to stumble off to the basement or garage to reset it.
Yes run a homerun with nothing but the bathroom on it.
100 amp panel is fine and presents no problem.
Old 01-22-2009, 11:59 AM   #6
Rewards Points: 150
so no need to get a gfci breaker but what about the recessed light? shouldnt that be directed with the gfci breaker? or is there a way to hook it up to the gfci receptical
Old 01-22-2009, 12:10 PM   #7
Rewards Points: 150
cant I just wire the recessed light to the gfci receptical so this way the light is protected also?
Old 01-22-2009, 01:46 PM   #8
joed's Avatar
You don't need a GFCI breaker. A GFCI receptacle is enough. Lights don't need to be GFCI unless over the tub. They can be if you want them. However it not recommended to put lights on GFCI. That way they stay on if you trip GFCI.
Old 01-22-2009, 02:00 PM   #9
Rewards Points: 150
yeah it is for my recessed shower light over the tub. should i connect that to the gfci outlet? or thats just too much? how about the fan?
oh yeah and why 20 amps. isnt that over kill? for a small bathroom?
Old 01-22-2009, 02:04 PM   #10
fix it
20 amps is required in a bathroom by code. If you're not familiar with a GFCI outlet, they "trip" when they sense a fault and cut the power. They must be manually reset to turn the power back on. You can wire other devices through the outlet, in your case, to provide GFCI protection to them without using a GFCI breaker. The breakers cost more than an outlet and as was mentioned you have wander to your main panel to turn the power back on if it trips.
detailedEye is offline   Reply With Quote
Old 01-23-2009, 10:08 AM   #11
Rewards Points: 150
cool. I got all my electrical parts yesterday. its hard to get the house ready when your working all 11 hours then after your work day you get to your new house and work on it for 4 and your beat lol... but tonight I will wire everything. do you think the shower/tub light recessed 4 inch 50 watt will be unecessary? or overkill?
gutted bathroom, have some questions and looking for ideas fabian Kitchen & Bath Remodeling 15 01-27-2009 08:23 PM
redoing 1950's bathroom sueray123 Remodeling 2 04-14-2008 05:42 PM
redoing bathroom sonnie1o6 Plumbing 5 10-25-2006 11:59 AM
