Old 05-28-2012, 08:06 PM   #1
bathroom gfi sharing
Can I put my bathroom dedicated 20 amp GFI receptacle in a double gang box and share that space with a general lighting or fan switch circuit?
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 05-28-2012, 08:09 PM   #2
Code05's Avatar
Yes you can.
Code05 is offline   Reply With Quote
Old 05-28-2012, 09:02 PM   #3
Licensed electrician
Be sure to tie both grounds together and to the devices.
Old 05-29-2012, 07:18 AM   #4
Electrical Contractor
As long as the gfci circuit does not feed another bathroom.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 05-29-2012, 07:54 AM   #5
From what I gather in the original post, he is only sharing the box, it seems as if he is saying that the lighting is on a different circuit. If that's the case, then that bathroom receptacle circuit can feed receptacles in other bathrooms.
Macro is offline   Reply With Quote
The Following User Says Thank You to Macro For This Useful Post:
jbfan (05-29-2012)
Old 05-29-2012, 08:00 AM   #6
Thanks, I misread it.
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 05:49 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
gutting bathroom debiasio Remodeling 30 02-17-2011 03:32 PM
Basement Bathroom Circuit PJ33P Electrical 1 02-12-2011 08:13 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 12:43 PM
