Bathroom Fan Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 02:37 AM   #1
Bathroom fan wiring
I'm hoping someone can help me out with this. I'm doing a remodel for a lower income family and I'm trying to replace a bathroom vent fan. The fan has a timer switch. The old fan had two "sets" of wires running into it. Two separate cables with a black, white, and ground apiece. When I took the old one out I had to snip all the wires so I never got a chance to look at how they were hooked up.
My question is: Why are there two cables? There are no lights in either the old or new fan vent. The new one only has the hook ups for one cable.
Flashman is offline   Reply With Quote
Old 06-28-2011, 04:37 AM   #2
Rewards Points: 1,192
Maybe timed on or other cable ...on.Don't snip wires till you know why they are there. 2 switches?
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
Flashman (06-28-2011)
Old 06-28-2011, 04:48 AM   #3
Originally Posted by Flashman
I'm hoping someone can help me out with this. I'm doing a remodel for a lower income family and I'm trying to replace a bathroom vent fan. The fan has a timer switch. The old fan had two "sets" of wires running into it. Two separate cables with black, white, and ground apiece. When I took the old one out I had to snip all the wires so I never got a chance to look at how they were hooked up.
Is the old unit a combination fan/heater unit? Why don't you trace where both wires go? Do they connect to switches/timers? Consider bringing in a licensed electrician to properly wire the fan and handle all the electrical for the bathroom remodel.
clydesdale is offline   Reply With Quote
The Following User Says Thank You to clydesdale For This Useful Post:
Old 06-28-2011, 06:20 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
2 cables running into the fan housing? One may be power, the other the switch leg to the switch.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
Old 06-28-2011, 02:27 PM   #5
Rewards Points: 468
Fan unit in ceiling 'plugs in' to an outlet usually so it can be unplugged and replaced when necessary. It would require only 1 pair of wires. If the tin housing in the joists for the fan was multi purpose as in fan/light, it could have been pre wired, just in case. A good electrician would have used a 3 conductor wiring, usually black/red/white. That assumes switch or switches in wall were designed to be from same location. There would be 2 outlets to plug into in the housing, a fan and a light. If it was more logical to have a light be turned on when entering the room from a different location, it could have its own switch somewhere else. It is much more difficult to add wires later, after construction. Having more is actually much preferred so you are better off. Just figure out (trace) where they start/finish. One pair may not be needed if light only.
diyorpay is offline   Reply With Quote
The Following User Says Thank You to diyorpay For This Useful Post:
Old 06-28-2011, 03:02 PM   #6
Licensed Pro
What Kyle said (post #4)
The Following User Says Thank You to HouseHelper For This Useful Post:
Old 06-28-2011, 05:20 PM   #7
Thanks for replies guys
I tried to trace the wires and they just go into a wall that is not getting remodeled so I have no idea where they go. Also it is very uncomfortable in the attic crawlspace, about 2 feet of crawling room between the joists and roof with a lot of insulation. As I said there is no other need for a wire, only the fan, no light or heater.
WHat do you mean the other switch leg Kyle? I'm not familiar with that term. Also how would I go about wiring it?
Today I hooked up just one of the wires hoping it would work and instead it just ran constantly without turning off so I had to unhook it again.
Old 06-28-2011, 07:13 PM   #8
Electrician
SD515's Avatar
Rewards Points: 504
Ahh…Sounds like you hooked it up directly to the source cable. I’d bet the other wire is the switch leg then.
A switch leg is where you have power enter a lighting box in the ceiling for example, then (pre-2011 code) you run a 2 wire cable (plus ground) from the ceiling box to the light switch, allowing a switch to be hooked up to control the fixture. There’s a proper way to do it, wire color wise, so if you don’t know, just ask us.
Kyle
Old 06-28-2011, 10:11 PM   #9
Thanks for reply Kyle
Yes if you could explain how the wires should go together that would be great. I've tried to research it and understand but I'm not completely confident in it. The way I understand it is (1). There is a hot 3 wire cable running to the fan. (2). There is another 3 wire cable going to the switch, and this is how the switch operates. (3) So from the hot wire, I hook the white directly to the fan, then I hook the black from the leg wire to the fan (colors matching the fan wires on both) then I hook the black from the hot wire to the white from the leg wire and ground both wires. Is this even close?
Old 06-29-2011, 06:21 AM   #10
Electrician
SD515's Avatar
Rewards Points: 504
Yep that’s it.
When you say 3 wire cable, I think you mean 2 wire with ground? Black, white, ground.
Source white directly to fan white,
sw leg black to fan black,
re-color the sw leg white at both ends (a sharpie works well for this)
source black to re-colored white.
both grnd wires together and to fan housing…may have to make a small jumper for this connection
At the switch, black to the sw, re-colored white to sw (doesn’t matter which terminal)
ground wire to sw,
Kyle
Flashman (06-30-2011)
Old 06-30-2011, 09:32 AM   #11
I'm off to try it today. Thanks for your help!
Wiring Bathroom fan to dual switch joerob25 Electrical 3 12-15-2010 11:11 AM
Need wiring help with a bathroom exhaust fan Brieninsac Electrical 3 04-16-2010 01:06 PM
Old wiring - Bathroom Light Psully24 Electrical 11 12-01-2007 01:20 AM
Help with bathroom wiring - URGENTLY NEEDED cfonseca Electrical 4 02-16-2007 02:42 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 10:40 PM
