Bathroom Fan Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2011, 02:05 PM   #1
Bathroom Fan Wiring
I have a bathroom fan that has a black and white wire running to it that goes up to a box and is spliced with another wire that runs directly to the box for an outlet and double switch in the bathroom. So there is no direct power to it. The light is fine on one switch, as is the outlet on it's own set of wires, both have power. My question is how do I power the wire for the fan? There was a wire that went between the outlet and switch, but I can't remember how it was hooked up. And all that was in use was a black and red wire in the switch box. Thanks.
jph2112 is offline   Reply With Quote
Old 06-25-2011, 04:52 PM   #2
Rewards Points: 6,652
Can you draw something in Paint, or Google Sketch-up how the wiring is from the circuit breaker to the outlet, then from the outlet to the junction box for the fan and lighting? What gauge is the wire for the circuit, and is the outlet a GFCI.
Old 06-25-2011, 06:29 PM   #3
Thanks, I was actually able to eventually figure it out.
Old 06-25-2011, 07:16 PM   #4
So, what was the problem?
Tags
bathroom , electrical , fan
Wiring Bathroom fan to dual switch joerob25 Electrical 3 12-15-2010 10:11 AM
Need wiring help with a bathroom exhaust fan Brieninsac Electrical 3 04-16-2010 12:06 PM
Old wiring - Bathroom Light Psully24 Electrical 11 12-01-2007 12:20 AM
Help with bathroom wiring - URGENTLY NEEDED cfonseca Electrical 4 02-16-2007 01:42 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
