Bathroom Fan And Light Wired Independently At End Of Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 05:32 PM   #1
Bathroom fan and light wired independently at end of circuit?
We are installing a new bathroom light and fan combo. I want them to work independently and the switches will be at the end of the circuit. I am familiar with a single pole at the end of a circuit but I am stymied how to do this short of just putting in a second wire, which we can certainly do. Is that the best way?
I want to also add that the fan light combo has 2 white wires, 1 blue (light) and 1 black (fan). There are no grounds?
Alexi637 is offline   Reply With Quote
Old 03-08-2010, 06:22 PM   #2
joed's Avatar
Rewards Points: 13,332
14/3 cable. Connect white to power black. At switch white is power to both switches. Red and black are the switch legs back to the fan and the light.
The Following User Says Thank You to joed For This Useful Post:
Alexi637 (03-08-2010)
Old 03-08-2010, 09:03 PM   #3
Electrical Contractor
kbsparky's Avatar
There is probably a ground screw in that fan/light unit, or a slot for a grounding clip to be installed.
joed outlined the proper wiring for the wall switches.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Old 03-08-2010, 09:09 PM   #4
" Euro " electrician
frenchelectrican's Avatar
I just want to remind the readers that the OP's situation it is a legit set up however the OP's 14-3 NM the white is hot conductor so it have to be remarked or taped with diffrent colours so that way you know it is not a netural at all.
Just in case someone else look at the switch box and not look carefull with connections and this set up I done few time before.
Merci,Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 03-08-2010, 09:32 PM   #5
Licensed electrician
Rewards Points: 1,766
Given the small size of exhaust fan junction boxes I would try to avoid running a switch loop.
