Old 09-12-2008, 11:40 AM   #1
Bathroom Fan/Light
I hooked up my bathroom fan/light to one switch so that when the light is turned on so will the fan. Problem is that in one position the fan is on and the light is off. When I flip the switch the fan turns off and the light goes on. Where did I go wrong?
will_53115 is offline   Reply With Quote
Old 09-12-2008, 11:58 AM   #2
Bathroom Fan/Light
Did you use a 3 way switch and hook up each wire to their own screw?
Wire nut the black wires that go to the fan and light with a jumper and then the jumper goes to the switch.
daxinarian is offline   Reply With Quote
Old 09-12-2008, 12:28 PM   #3
Licensed electrician
Bathroom Fan/Light
Sure sounds like a 3 way switch was used. Power in on common and the 2 normal screws for travelers were used for the switched hots to the fan and light.
Did you use a 3 wire cable to the fan/light? Black, red, white and ground.
Old 09-12-2008, 03:24 PM   #4
Bathroom Fan/Light
My first thought also was a 3 way switch. I've accidentally grabbed one of those without looking.
dac122 is offline   Reply With Quote
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 07:45 PM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 11:10 AM
