-   -   Bathroom Fan/Light (http://www.diychatroom.com/f18/bathroom-fan-light-26708/)
will_53115 09-12-2008 11:40 AM
Bathroom Fan/Light
I hooked up my bathroom fan/light to one switch so that when the light is turned on so will the fan. Problem is that in one position the fan is on and the light is off. When I flip the switch the fan turns off and the light goes on. Where did I go wrong?
daxinarian 09-12-2008 11:58 AM
Did you use a 3 way switch and hook up each wire to their own screw?
Wire nut the black wires that go to the fan and light with a jumper and then the jumper goes to the switch.
Jim Port 09-12-2008 12:28 PM
Sure sounds like a 3 way switch was used. Power in on common and the 2 normal screws for travelers were used for the switched hots to the fan and light.
Did you use a 3 wire cable to the fan/light? Black, red, white and ground.
dac122 09-12-2008 03:24 PM
My first thought also was a 3 way switch. I've accidentally grabbed one of those without looking.
