Bathroom Fan Help - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2009, 02:54 PM   #1
bathroom fan help
hi guy's
please could someone help, we have a onsuite and there is only one switch, and this turns on the light and the fan, i want to change this to have two switch's so we can either turn on fan or light, its a bloody pain getting up in the night wanting to just put the light on, and have the dam noisy fan come on
can this be done simple, i have got the box and switch
thank you
paul1969f is offline   Reply With Quote
Old 10-25-2009, 03:30 PM   #2
Electrician
Rewards Points: 778
Chances are that it won't be easy. You will have to open your switch and see what you have for wires. If the fan and light both come back to the switch then it is easy, if not you would have to get a new wire to the fan.
Take a look inside your switch and let us know what you have for wires.
darren is offline   Reply With Quote
Old 10-26-2009, 02:28 PM   #3
Rewards Points: 410
x2
In most cases the installer takes the easiest route... here that would mean running a wire from the switch to the light, and then attaching the fan to the light. Turn on the light you turn on the fan too, but the fan is wired to the light, not the switch.
What you're looking for is for the fan to be wired to the switch instead of the light. The only scenario's I've come across they would do that (since it's more work, time, and materials) is when the homeowner specifically asks/pays for it just on the whim they may want them separate later. The other scenario, is when they're seperate to begin with but the kids keep forgetting to turn on the fan when they take their showers. Parents get sick of reminding their kids so change them to be controlled by the same switch. It can easily be put back to seperate switches that the case.
It's pretty rare unfortunately for the above conditions, and likely you need to run a wire from the switch box to the box controlling the light to do this. Like Darren said though, we need to know what's behind the current switch you may be lucky.
Piedmont is offline   Reply With Quote
Old 10-26-2009, 05:12 PM   #4
i will take a look later and get back to you all thanks
Old 10-26-2009, 07:18 PM   #5
Why not replace the fan with an upgraded model that makes less noise? I have a small condo, and the builder installed upgraded fans with a timer system to allow them to run on for hours at a time. The purpose is to allow air circulation in our little rectangle apartment, as we do not have cross ventilation as one does in a house. The fan is quiet, and allows for a white noise effect as it is on near constantly.
mtpleasantowner is offline   Reply With Quote
Old 10-26-2009, 07:31 PM   #6
thats a good idea, i might do that, i will weigh up the cost's
Basement bathroom rough in efrobert Plumbing 2 06-23-2011 05:54 PM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 12:04 PM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 11:10 AM
