Bathroom Fan/Heater On A 15-amp Circuit Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 05:10 PM   #1
Bathroom Fan/Heater on a 15-amp Circuit Breaker
I bought a 'panasonic' light/nightlight/fan/heater combo unit. Now that I received it, checked the Operating Instructions. It stated in one of the warnings to "Use only 20 ampere branch circuit.". It didn't show that important fact in the website technical specs.
I have one (1) 15-amp circuit for the bathroom.
I considered the option of upgrading the 15-amp circuit for lighting to a 20-amp BUT UNFORTUNATELY the wiring that I currently have for the 15-amp has only 14-gauge. The minimum wire size for a 20-amp is 12-gauge.
It does say in the technical specs that the COMBINED AMPS is only 12.5.
So, my dad (whose an electrical engineer) did some calculations using all the lights, heater, & fan. He said that based on calculations, it's safe to install the unit to a 15-amp circuit breaker.
Is there anybody who thinks otherwise?
paisley13460 is offline   Reply With Quote
Old 06-01-2011, 05:34 PM   #2
Licensed electrician
Rewards Points: 1,876
By Code you are supposed to follow any instructions given by the manufacturer. To do otherwise would create a code violation.
Old 06-01-2011, 05:35 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Yes, me.
If the instructions as a 20A circuit you must install it on a 20A circuit.
I know this is not the answer you want to hear but it is the only correct one.
I'll admit, this information is buried in the instructions .pdf on the Panasonic web site, but it IS there.
http://www2.panasonic.com/webapp/wcs...2&displayTab=R
Old 06-01-2011, 05:38 PM   #4
I actually called their customer service. They told me that the 20-amp is just highly recommended but not required.
I guess they put 20-amp just so nobody would sue them.
Old 06-01-2011, 05:40 PM   #5
If this is a fact then do what you gotta do.
Thing is, this unit will pretty much max out a 15A circuit. How much else is on it?
Old 06-01-2011, 05:42 PM   #6
Is there anything in the Electrical Code that indicates a bathroom fan/heater is required to be on a 20-amp circuit?
Old 06-01-2011, 05:55 PM   #7
No, but there is something that states we MUST follow manufacturer's instructions.
Old 06-01-2011, 06:03 PM   #8
How hard is it to add a 20-amp circuit breaker?
Old 06-01-2011, 06:11 PM   #9
You would need to run a new #12-2 cable back to the panel and have space for a single pole breaker.
Old 06-01-2011, 06:14 PM   #10
My Circuit Breaker Panel is on the 1st floor. My bathroom is on the 3rd floor. Does that mean opening up walls & ceilings?
Old 06-01-2011, 06:58 PM   #11
Rewards Points: 127
code vs. safe
What if you received something from the manufacturer in writing on letterhead stating that installation on a 20A circuit is strongly recommended but not required? (Probably impossible!)
If installation on a 15A circuit is safe, would this satisfy the code requirement regarding compliance with the manufacturer's requirements?
Daneel is offline   Reply With Quote
Old 06-01-2011, 07:46 PM   #12
Extremely simple.
The hard part is running the wire up three floors.
Old 06-01-2011, 07:47 PM   #13
I thik a verbal from them is adequate. It's (probably) not like this is something that will be checked by someone.
Old 06-01-2011, 07:57 PM   #14
I have a question for you, Speedy Petey
In the other bathroom that I would like to install a bathroom heater... has a 20-amp circuit breaker for all the gfi outlets (which actually is only 2 gfi outlets). Can I connect the heater/fan unit to that?
Old 06-01-2011, 08:31 PM   #15
In the other bathroom that I would like to install a bathroom heater... has a 20-amp circuit breaker for all the gfi outlets (which actually is only 1 gfi outlet). Can I connect the heater/fan unit to that?
I wouldn't. Depending on the conditions this may be a code violation, in any case it is a bad idea.
Are you saying it is just one GFI receptacle, in the one bathroom, on the 20A circuit?
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
900W and up trips breaker, Circuit draws power even with everything off... jasonblu Electrical 40 12-09-2009 02:29 PM
Federal Pacific stab-lock circuit breaker Mike in Arkansas Electrical 4 11-29-2009 09:07 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
