Old 01-07-2012, 03:18 PM   #1
Bathroom exhaust vent question
Hi-
I'm trying to avoid making a hole in my roof for an exhaust vent. Instead, I'd like to run the flex duct over the top of the ceiling joists, down into an existing chase and 90 out the side wall. So, there would be 2-90 degree turns in the duct and the air would flow down before getting outside.
Is this just a really bad idea?
Thanks.
Testarossa214 is offline   Reply With Quote
Old 01-07-2012, 03:32 PM   #2
Electrical Contractor
kbsparky's Avatar
Some questions to consider:
How long is the proposed run of ductwork?
What material are you planning to use for the duct, plastic or metal?
What size is the duct?
What is the CFM rating of the fan?
-KB
kbsparky is online now   Reply With Quote
Old 01-07-2012, 03:49 PM   #3
We're using a broan/nutone standard (cheap) fan and the wall vent kit that they sell with it. I'm not sure of the cfms. The run is about 6 feet across and then about 2 feet down. The duct itself is that flexible slinky- type silver (Mylar?) coated 4" dia. duct.
Old 01-07-2012, 03:51 PM   #4
kbsparky's Avatar
That short of a run should be do-able.
-KB
Old 01-07-2012, 04:42 PM   #5
Electrician
What type of roof do you have, do you have a gable end. If so you can run out the soffit vent, if you do this I would recommend getting the insulated line if it is going through your attic.
darren is offline   Reply With Quote
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 11:14 PM
Yet another bathroom exhaust fan venting question JulesB HVAC 23 03-10-2011 04:16 PM
Bathroom exhaust vent clearances stubits HVAC 6 02-22-2011 12:12 PM
combining dryer vent with bathroom exhaust fan tibo613 Plumbing 2 11-06-2010 10:36 PM
