Bathroom Exhaust, Light, Heater Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2012, 09:15 AM   #1
Bathroom Exhaust, light, heater switch
While attempting to replace an old switch to bathroom exhaust, I found,,, old switch has 2 neutral, and two hot legs, one jumper from neutral to hot. new 3 pole switches have only one hot. For now no configuration works. Really do not want to have to rewire entire circuit.
shortedout is offline   Reply With Quote
Old 07-11-2012, 09:53 AM   #2
Licensed electrician
Rewards Points: 1,278
Normally a switch would not control a neutral. The neutral should be unswitched.
You are going to need to determine the function of each wire and we can go from there. Do you have a test meter?
Old 07-11-2012, 10:05 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm guessing it was 1 hot/3 switch legs....no neutral. Just because the wire has white insulation doesn't mean its a neutral.
Old 07-12-2012, 11:50 AM   #4
Yes, The back of the old switch has 3 hot feeds, 3 neutral feeds. Bottom and top are used and middle are jumped from top and bottom in X pattern. I have been told these switches are no longer available. The new ones only have one feed in and 3 out. While i have not taken the time to trace each wire to fan/light/heater itself. I understand how each works. While not licensed, i do understand the basics, and have done several projects inc. 3way, etc. Been in home building for about 25 years but this one has been a headache. Contacting a local friend, (local licensed el. cont) Thanks, i just like figuring this out on my own with assistance from sites as this if i can. But, SAFETY FIRST!
Old 07-12-2012, 11:52 AM   #5
Millions of tires wear out every day?? Where does the rubber go? Should be piled up on sides of road like snow in winter.
Old 07-12-2012, 12:19 PM   #6
k_buz's Avatar
What's with all the nonsense posts here lately? Its like I'm talking to a group of 4 year olds who just drank Mountain Dew.
Old 07-12-2012, 12:24 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Just me, but I think he was remarking to your sig.
Old 07-12-2012, 12:28 PM   #8
k_buz's Avatar
Fixed it...if that was the problem.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 06:58 PM
location of light and fan switch in Master bathroom Bonnell Electrical 10 04-15-2012 10:07 AM
Problem replacing bathroom lightswitch rockchalk Electrical 7 12-19-2011 07:57 AM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
