Bathroom Exhaust Fan Without Ground? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2009, 05:33 PM   #1
Rewards Points: 109
Bathroom exhaust fan without ground?
Just installed Fantech remote fan. Ran 12/2 romex to the attic from a load side of GFCI outlet through a timer switch. All kosher until I got to the attic to make the actual fan connection. Guess what? No place to connect the ground wire. Fantech installation manual says
"Since the fan motor is isolated within a plastic housing, grounding is not necessary."
Is this OK? I left the capped ground wire in the fan junction box. Will GFCI still trip IF there's an issue?
BimmerRacer is offline   Reply With Quote
Old 08-30-2009, 06:08 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Do you have the link for that manufacter I will like to see that statement what they are saying there.
Merci,Marc
Old 08-30-2009, 07:35 PM   #3
Rewards Points: 109
Marc,
This is the line to the manual http://www.fantech.net/pbmanual06012009.pdf
Old 08-30-2009, 08:58 PM   #4
BCSparkyGirl's Avatar
I have installed dozens of these, and no, you are not required to ground the fan. I do just what you say you have done, although it is not necessary to cap the ground.
BCSparkyGirl is offline   Reply With Quote
Old 08-30-2009, 10:45 PM   #5
Ok I read it and no you do not need to ground them as long the instruction stated that so you are good to go.
Merci,Marc
Old 08-31-2009, 12:36 AM   #6
Rewards Points: 109
OK, I'll leave it as is. Thanks
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Bathroom exhaust fan causing ice dam Arton Roofing/Siding 5 01-30-2009 04:35 PM
Bathroom Sink Drain (Broken from wall to Ground) bli182nk Plumbing 2 01-11-2009 07:52 PM
New wiring and switch for bathroom exhaust fan looking4help75 Electrical 9 06-27-2008 04:15 PM
Bathroom Exhaust Fan/Heater/Light: Panasonic, NuTone or Air Zone? Tom's Diner HVAC 7 05-07-2008 08:53 AM
