Bathroom Exhaust Fan Rewire - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 01:04 PM   #1
Rewards Points: 262
bathroom exhaust fan rewire
Existing Broan 757PT ventilation fan/light installed in existing bathroom.
http://www.broan.com/display/router....oductID=100285
I need to get at the wiring and there is absolutely NO way I can find to do that without removing the whole box, which is anchored to joists above the ceiling. There is no way to pull just the fan motor down through the housing. Anybody got any tips on what I may be missing? Do I really need to basically uninstall this thing to access wiring?
tpagel is offline   Reply With Quote
Old 05-22-2011, 01:21 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
why do you need to access the wire?
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-22-2011, 01:28 PM   #3
Electrical Contractor
If you look at pg. 4 of the installation guide, it shows you how to remove the motor and get to the electrical connection box.
hpp58 is offline   Reply With Quote
Old 05-22-2011, 01:49 PM   #4
Rewards Points: 262
That was the first place I looked. The dashed boxes show what comes as a unit. I thought the flat plate with the motor attached would drop down, but I spent 15 minutes on it, trying to loosen the tab connections, but that doesn't seem to work. I will try again. I need to access the wire because it was connected to some outlets I need to remove as part of a kitchen renovation. I can't abandon the live wire up in the ceiling, so I am trying to disconnect it from the adjacent room's fan, to leave only the fan on the circuit.
Old 05-22-2011, 01:51 PM   #5
Rewards Points: 262
I can take up a portion of the subfloor in the level above, but since I didn't install the fan, I don't know if there is any way to access the wires from above either.
Old 05-22-2011, 02:15 PM   #6
Licensed electrician
Rewards Points: 1,762
Deflect the housing outward near each of the tabs.
Old 05-22-2011, 02:20 PM   #7
Rewards Points: 262
Damn, Jim! That was easy. I kept trying to push up on the plate, but the housing is such that there is no way to move it upward. Doing as you said worked great. Thanks so much for sparing my wife from hearing even more foul language!
Bathroom exhaust vent clearances stubits HVAC 6 02-22-2011 11:12 AM
Condo Bathroom exhaust fan schnitz411 HVAC 0 05-26-2010 04:59 PM
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 07:41 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 10:57 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
