Old 04-27-2011, 11:53 AM   #1
Bathroom exhaust fan/light timer switch
Hello:
I was wondering if anyone could recommend or comment on a timer switch that will turn the light off and leave the fan on for a set amount of time. Most switches I see are timed to leave the fan and light on at the same time but I wanted a switch that will shut the light off and leave the fan on for a preset time. the only one I could find is this one:
http://www.ventingdirect.com/air-kin...LAID=854443250
Are there others out there? This one is nice but it would be hard fotr any guests to understand it since the plate will cover the on/off/time.
Thanks!
zephed666 is offline   Reply With Quote
Old 04-27-2011, 11:59 AM   #2
Stay-at-home GC
We used the Broan light, fan, heater combo. All three appliances within the unit are on separate switches with the heater being on a separate circuit. I put them in a 3 gang box with the fan on a timer. Then had my wife label the switch plate in calligraphy pen, Light, Fan, Heat.
Looks very nice.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 04-27-2011, 12:00 PM   #3
Looks very nice.
I only have room for one switch so I am looking for a combo one...
Old 04-27-2011, 12:01 PM   #4
Stay-at-home GC
Sorry, I suppose I should have tried to answer your question, instead of just running my mouth.
Would labeling the switch plate allow you to use that switch?
My guess is you do not want to swap out fan units and add a circuit.
Old 04-27-2011, 12:07 PM   #5
I could label the switch plate, just wondering if there are other options out there.
Old 04-29-2011, 09:00 AM   #6
Air King makes a model called AKEDT2 thats is an electronic version with an automatic timer
http://www.airkinglimited.com/canadi...st/delay1.html
http://www.ventingdirect.com/air-kin...-timer/p989044
Air Cycler makes a unit called SmartExhaust that has a few more features, adjustable timer, and an hourly vent cycle.
http://www.aircycler.com/productline.htm
I don't think that the AKEDT2 has an override that you can use to shut of the fan when you don't want it.
I'm planning to install either the AKEDT2 or the SmartExhaust depending on what i can source here in Canada
Paul
pgartner is offline   Reply With Quote
Old 04-29-2011, 09:18 AM   #7
Paul
Thanks! I think I am going with the AKDT63. I read about the AKEDT2 and I don't believe you can shut the fan off and just use the light. It is pretty much an electronic version of the AKDT63.
Old 04-29-2011, 12:25 PM   #8
personally I like the smartexhaust, the ability to override the fan is nice. for my basement bathroom/laundry it would be good as we don't often take showers down there. and as a plus the hourly scheduled timer could help down there to circulate the air in the basement.
in the master bath (that i'm in the process of completely redoing) the the light that the fan is on is over the shower. so any timed fan function would work
Paul
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Water Dripping Out Bathroom Exhaust Hood Caulk? leftygroove General Discussion 7 03-08-2011 08:53 PM
Wiring for ceiling fan/light with dual switch at end mcherno925 Electrical 26 10-22-2010 12:41 PM
Installing timer switch, no ground wire in switch box diydan Electrical 2 05-25-2009 08:51 PM
Bathroom exhaust fans PirateKatz HVAC 7 11-18-2008 04:09 PM
