Old 04-25-2010, 06:30 PM   #1
Bathroom Exhaust Fan / Heat Lamp wiring question
Timer Switch # 1 (to heat lamp) / Timer Switch # 2 (to exhaust fan)
Both timers are 5 amps and have Black, White, and Ground wires.
I want to wire both timers to work a Bathroom vent fan / heat lamp separately.
White / Black / Green wires come from Fan side
White / Blue comes from heat lamp side.
Can anyone tell me how to wire this correctly?
MCrom is offline   Reply With Quote
Old 04-25-2010, 06:51 PM   #2
Licensed Electrician
Magnettica's Avatar
Send a message via Yahoo to Magnettica
Three-wire from your supply source to the fan assembly. I normally use the red for lighting (heat lamp) and the black for the fan (exhaust). Check the wattage of the lamps you're going to use because you may need a dedicated circuit for this as to not overload the existing circuitry. If you're installing this in attic space and you should vent to the outside, use a minimum 4" flexible insulated venting kit.
Union County, NJ, Licensed Electrician
Magnettica is offline   Reply With Quote
Old 04-26-2010, 09:30 PM   #3
Thank You, All is well...
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Bathroom wiring ATShome1 Electrical 6 02-26-2010 10:30 AM
Bathroom Exhaust Ducting Question ande3171 General Discussion 2 04-20-2009 06:59 AM
Bathroom exhaust fans PirateKatz HVAC 7 11-18-2008 04:09 PM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 06:44 AM
