Bathroom Exhaust Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 01:20 PM   #1
al99's Avatar
Bathroom exhaust fan
I need to install a ceiling fan in remodeled bathroom,it has one switch for the lights over vanity and no others,I need to wire for exhaust fan,question is can I use existing wirin at the switch and run new wire to fan and how do I wire from one switch to the other?Hope the question makes sense.Thanks for any help you can offer and I almost forgot I have Alum wiring in home ,but will be running Cu to new fan.Thanks again.
al99 is offline   Reply With Quote
Old 11-07-2013, 06:32 PM   #2
joed's Avatar
Rewards Points: 12,388
It depends on the existing wiring at the switch. If you only have one cable with two wires then it is a switch is a switch loop and you do not have a neutral wire.
If you have two white wires in the box not connected to the switch then you can do it.
The Following User Says Thank You to joed For This Useful Post:
al99 (11-07-2013)
Old 11-07-2013, 06:37 PM   #3
Oso954's Avatar
Rewards Points: 1,008
Because of the aluminum wiring, I would get an electrician so you know the transitions are made correctly.
Oso954 is offline   Reply With Quote
Old 11-07-2013, 09:40 PM   #4
joed's Avatar
I missed the aluminum wire bit. It takes special connector to join copper to aluminum.
Can I put my bathroom exhaust fan outlet where I want to? danielrg HVAC 9 04-07-2013 07:44 AM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 10:36 AM
adding can lighting and bathroom exhaust fan to aluminum wired house matjam68 Electrical 2 03-22-2010 10:50 AM
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 07:41 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
