Bathroom Ckt. Gfci Is Afci Okay? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2009, 05:46 PM   #1
Bathroom ckt. Gfci is Afci okay?
With the new NEC code 2008, which I only know by hear say, can you use a AFCI ckt brkr vice the GFCI ckt breaker?
luweee is offline   Reply With Quote
Old 05-31-2009, 06:48 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Originally Posted by luweee View Post
...can you use a AFCI ckt brkr vice the GFCI ckt breaker?
Are you asking if you can use an AFCI versus a GFCI breaker?
If so, then NO, not for a bath receptacle.
You can use a GFI receptacle fed from an AFCI breaker if you really had to, but there is no valid reason for doing this.
Speedy Petey is online now   Reply With Quote
Old 05-31-2009, 07:55 PM   #3
I must not understand this properly then.
I installed a 20 AMP AFCI ckt breaker at the circuit panel.
I then installed a GFCI receptacle in the bathroom.
Is this a correct installation??
Old 05-31-2009, 07:58 PM   #4
Bathroom is only required to be GFCI protected
Old 05-31-2009, 08:19 PM   #5
Right.
And you CANNOT mix a bath receptacle circuit with other rooms, so an AFCI breaker is completely unnecessary.
Old 05-31-2009, 10:30 PM   #6
" Euro " electrician
frenchelectrican's Avatar
The bathroom circuits are required have GFCI recepale or breaker but not the AFCI it not needed at all.
{ Ditto for kitchen applaince circuits as well }
Merci,Marc
Old 05-31-2009, 10:59 PM   #7
I only have the bathroom on this ckt.
I over did it, I hae an AFCI ckt brkr and a GFCI receptacle in the bathroom.
But it is okay to have it on a AFCI, correct?
Old 05-31-2009, 11:15 PM   #8
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
yes, it is.
but to all the other gurus:
I do not have my '08 handy at the moment and have not had to deal with AFCI as my work is commercial/industrial but;
what about the AFCI requirement in the '08 code for full house install? OP never said if this is new or existing
Old 05-31-2009, 11:57 PM   #9
Electrical Contractor
kbsparky's Avatar
Doesn't matter, if it is a new house or old. Fact is, the OP can install an AFCI breaker for a bathroom GFCI outlet, if he wants to.
The Code does not require this but does not prohibit this either.
Old 06-01-2009, 12:40 AM   #10
Rewards Points: 506
Send a message via AIM to theatretch85
On my recent basement re-wire and main panel replacement, I wired the entire bathroom on its own 20 amp standard circuit (non-GFCI/AFCI) and just simply installed a GFCI outlet independent of the lights.
For my wet bar area, since there is an outlet behind the fridge, behind the bar (on the wall, will be under some shelving) and continues around to where it will eventually be fed into the bar itself for some counter-top outlets I put that circuit on an AFCI breaker and used GFCI outlets. I wasn't sure if it was required to be AFCI because of where some of the outlets for that circuit are in the family room downstairs.
Also, I was required to install at least one GFCI outlet in the un-finished area of the entry way from the garage in the basement, along with a couple other outlets in and around the laundry room area and down the hallway. Probably 6 or 7 outlets and most are GFCI or GFCI protected standard outlets (tamper resistant of course) and this circuit is also a AFCI circuit since there was one outlet installed in the hallway part of the "living space". Eventually the entry way will be all finished off and I can probably remove some of the GFCI outlets and use them out in the garage instead when I add some additional power out there.
Bottom Line, it certaintly won't hurt to have the AFCI protection, I haven't had ANY issues with nuisance tripping like I was fearful of (I've installed 6 AFCI circuits so far here), just overload tripping (20 amp circuit via 12 gauge extension cord to the garage with table saw, air compressor and miter saw doesn't work too well).
theatretch85 is offline   Reply With Quote
Old 06-01-2009, 06:04 AM   #11
I had an inspector make us put a AFCI Breaker on a GFI outlet in the bathroom because there was no door that separated the bedroom and the bathroom.
williamj001 is offline   Reply With Quote
Old 06-01-2009, 06:19 AM   #12
The new "whole house" requirements are greatly exaggerated. Very basically, areas that require GFI protection do not require AFCI protection.
He was wrong IMO. A bathroom is still a bathroom. Door or no door.
That is like saying a bathroom with a walk out shower would make the whole room a shower. If that were the case you would not be allowed any switching or receptacles.
Old 06-01-2009, 06:25 AM   #13
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
That's funny, I had one try that on me, not because of the door issue but because it was "connected" to the bedroom. I was like "well so does the great room and the great room's connected to the kitchen and the kitchen is connected to....so, where does it end"? He then changed his mind.
wirenut1110 is offline   Reply With Quote
Old 06-01-2009, 03:07 PM   #14
nap
You talking to me?
nap's Avatar
thanks. It had been awhile since I had dealt with the AFCI stuff. Not applicable in my arena.
Old 06-02-2009, 02:24 AM   #15
i just remembered that it was the other way around, I had to install a GFI on the AFCI crucit and the bathroom remained only the GFI.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
A few questions regarding GFCI AND AFCI protection CowboyAndy Electrical 5 03-10-2008 03:20 PM
Best way to wire this Bathroom? GFCI, Drawing inside twilightcall Electrical 31 01-21-2008 09:29 AM
Bathroom Vanity Lights... after GFCI? CuCullin Electrical 4 11-12-2007 03:16 PM
Extending a GFCI in the bathroom diamondking Electrical 10 05-01-2007 05:48 PM
