Bathroom, 15 Or 20 Amp? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2008, 06:49 PM   #1
Bathroom, 15 or 20 amp?
I read here and everywhere else that batroom should be 20 amp. But I was reading Black&Decker home wiring book and there is a sample of a plan and it states 15 amp.
Can you use 15 amp for 1/2 bath atleast?
ptcamaro is offline   Reply With Quote
Old 04-29-2008, 06:54 PM   #2
Rewards Points: 1,190
A bathroom receptacle must be 20a. Black & Decker is just wrong, and not just about bathroom wiring.
LawnGuyLandSparky is online now   Reply With Quote
Old 04-29-2008, 07:13 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
It might be an old book. Years ago a dedicated 15A circuit was code legal. Not a good idea, but legal.
Speedy Petey is online now   Reply With Quote
Old 04-29-2008, 07:28 PM   #4
Rewards Points: 6,652
The book I have, shows 14/2 (15a) for Lighting, and 12/2 for (20a) circuit on page 159. This is under NEC 2005, but the drawing shown is for more of example purposes, and most likely to simulate what a homeowner had drawn out for what was in the home.
Old 04-29-2008, 07:42 PM   #5
Licensed Pro
Bathroom lighting on a 15A (14/2) is OK, as long as there is a separate 20A (12/2) circuit for the receptacles.
Old 04-29-2008, 07:49 PM   #6
I had to look at the drawing a 2nd time, and it is wired from a Sub-Panel, in order of wiring: GFCI, with a leg to the switch, and to a Closet light. From the switch, it goes to the light above the sink, and Vent fan. The Wall heater comes off of the same sub-panel, to another heater in the loop.
Their description is:
Circuit #1: A 15-amp, 120-volt circuit serving the bathroom and closet area. Includes: 14/2 NM cable, double-gang box, timer switch, single pole switch, 4x4 box with single gang adapter plate, GFCI recepticle, 2 plastic light fixture boxes, vanity light fixture, closet light fixture, 15-amp single pole breaker.
The space is a 400-sq ft. space.
Old 04-29-2008, 07:55 PM   #7
Licensed Pro
If they are including the GFCI for the bathroom, then , yes, that is definitely wrong. Probably written by a former HD employee.
Old 04-29-2008, 08:07 PM   #8
Maybe written by someone in China. lol
Old 04-29-2008, 09:53 PM   #9
Registered User
Termite's Avatar
Whoever wrote it...
They didn't have a code book.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
Second level / attic bathroom size moneymgmt General DIY Discussions 2 05-02-2007 07:32 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
