Old 12-14-2011, 07:22 PM   #1
Limited Experience
Bath Wiring Question
Remodeling our townhouse and am fixing bathroom wiring. Currently the upstairs baths have lights, fans, outlets all on the same breaker that also controls other outlets in the house.
So I plan to put the outlets for both baths on one 20A breaker which I understand meets code.
Plus I'll move the lights and fans to a separate breaker. But can this breaker be shared with other lights in the house. Bedroom lights in this case.
raleighthings is offline   Reply With Quote
Old 12-14-2011, 10:28 PM   #2
Licensed electrician
The bedroom lighting can power the bath fans and lights if the circuit has reserve capacity.
If it were me I would run a circuit for each bathrooms receptacle.
Old 12-14-2011, 10:34 PM   #3
Limited Experience
If the basics didn't fill the panel, so would I.
Old 12-14-2011, 10:37 PM   #4
Electrician
SD515's Avatar
Originally Posted by raleighthings View Post
... But can this breaker be shared with other lights in the house. Bedroom lights in this case...
Yes, but it will most likely have to be an AFCI breaker since it’s a bedroom. Different areas of the country have different requirements for Arc-fault breakers. Here in Michigan, we are on the 2008 code, and though the ’08 code requires AFCI’s nearly everywhere in a house, our state only requires bedrooms to have AFCI protection. Best to check with your local jurisdiction.
Kyle
Old 12-15-2011, 12:45 PM   #5
Limited Experience
Sigh. AFCI requires a new panel. I wonder if I can get the wiring permitted without AFCIs then hire an electrician to do the panel. It's old and only basic replacement breakers are available.
On a side note, how do AFCIs work with things like TIVOs. A TIVO box does not have an on off switch. Just a power cord as it has to be running 24/7 to operate correctly. Do you have to put a power strip in between the TIVO and outlet with AFCI breakers just to keep from tripping the breaker when the TIVO is plugged in?
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 10:43 AM
Low Voltage Wiring Question.. scyarch Electrical 3 10-23-2011 12:00 PM
Wiring question fabian Electrical 7 07-28-2011 04:31 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
