Bath Vent Fan Replacement - Electrical - DIY Chatroom Home Improvement Forum
Old 10-14-2011, 12:07 PM   #1
Bath vent fan replacement
I have a 20 yr old Broan(99110579)fan on the ceiling that doesn't work.
I turn on the wall switch and nothing moves, just hear a low
humming noise.
Not worth fixing it since a newer one would be a better option
and much quieter. I would like to buy one the same size, the hole
in the ceiling is 7 3/4 x 7 3/4, the size of the bathroom is "66x 60"
it's in the basement with no window in the bathroom, it's vented to the
outside from the fan. I don't need one with a light, any brand recommendations? Is this a DIY job for somebody like me
with little electrical work experience? thanks
pinecone12 is offline   Reply With Quote
Old 10-14-2011, 12:55 PM   #2
Rewards Points: 758
Broan makes an "upgrade" kit that includes a new, 3.0 sone motor, and a new grill. It may fit your model.
Here's a link: http://www.broan.com/display/router....oductID=100402
AandPDan is online now   Reply With Quote
Old 10-14-2011, 04:00 PM   #3
Thanks, my model number is listed, however the housing dimensions are
slightly off, it's for 7 1/2 X 7 1/4" only. Then again I only measured the
outside of the hole, when I get home later I will turn the fuse off and disconnect the fan and make sure I have the right measurement.
I would be going from 50 CFM's 2.0 Sones to 60 CFM's 3.0 Sones.
Not much difference there I believe, would prefer a quieter fan(2.5 or less) but I can live with it.
The price for the upgrade kit is $54.16+$8.95 for S&H+tax, considerably less then a new unit. Best part is that it's easy to install.
Edit: After speaking with Broan customer support, I was told that my model has a housing of 8 1/4 x 8. The new ones have the 7 1/2" x 7 1/2" housing size. Oh well it lasted 23 years, time for a new fan now.
Old 10-14-2011, 06:51 PM   #4
Licensed electrician
Rewards Points: 1,622
The Broan/Nutone LS series are quieter than the QT series. They may be more fan than you need. IIRC the small ones are around 80 CFM.
Old 10-15-2011, 02:19 PM   #5
The Broan customer service dept is closed for the weekend.
I removed the old vent fan and measured the housing from the
bottom, it's 7 3/4 x 7 3/4, I didn't remove it, but I want to know
if it's bigger on the top of the housing or the same.
The upgrade kit is for 7-1/2 x 7-1/4 housing only.
Old 10-15-2011, 02:24 PM   #6
Rewards Points: 6,652
pinecone12, all you need is the fan. If it fits into the existing hole, otherwise, you may be best to pull out the old unit and replace with a newer one. I looked at ours, and it is a 50cfm @ 2.5 sones, but it is still pretty loud.
Old 10-15-2011, 03:50 PM   #7
Rewards Points: 1,192
Sometimes you need a noisy fan.
bobelectric is offline   Reply With Quote
Old 10-17-2011, 09:54 AM   #8
Old fan, old housing.
Still searching for the right sized fan....
Old 10-17-2011, 10:00 AM   #9
As already stated, drill out the rivets holding the old motor and install the new motor.
Old 10-21-2011, 10:01 AM   #10
Ok, trying to reinstall the new motor into the old housing, I forgot how it was when I removed the old motor/fan assembly from the housing. All I know is that I have to plug in the new motor to the receptacle, but what about the wires? push them through the hole of the housing? thanks.
http://i2.photobucket.com/albums/y28...tyal/004-1.jpg
http://i2.photobucket.com/albums/y28...tyal/005-2.jpg
http://i2.photobucket.com/albums/y28...tyal/003-2.jpg
Bath fan vent stays open? joe from clev Remodeling 3 06-23-2010 11:08 PM
Bath P-trap related to tee and stack vent Jim F Plumbing 2 03-29-2010 10:04 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
Trane XE 80 vent motor replacement DJfixer HVAC 3 12-26-2008 02:15 PM
