Bath Lighting Connection Box - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 12:56 PM   #1
I have a wiring box above a large mirror in a bath. After removing the lighting fixture to remove (2) layers of wallpaper found that the 'box', don't know what its really called was found to be simply in the wall with no attachments to studs or anything? Is this correct?
How should this wiring box be attached? Sorry for not knowing the correct terms but now know why when changing the bulbs it felt somewhat loose!
What could I do to secure it as am thinking about replacing the light fixture but as it is don't think it would hold the one the wife picked out as it's quite a bit heaver than the existing fixture?
Thanks!
pinkfloyd43 is offline   Reply With Quote
Old 12-17-2012, 03:20 PM   #2
TTW
TTW's Avatar
Run down to the old big box store or hardware store and grab a round "old work box", one of those blue plastic ones will work fine. They have little ears that tighten against the back of the drywall to hold them in. Just don't use your drill to tighten them! Do it by hand.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
The Following User Says Thank You to TTW For This Useful Post:
pinkfloyd43 (12-17-2012)
Finishing a basement bath Vent? Pump-up toilet connection heenanp Plumbing 0 03-23-2010 07:43 PM
DIY Lighting Fixture stubits Electrical 11 10-13-2009 02:20 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 03:52 PM
