Bath Fan And Light Wired Together - Any Issue? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 07:36 PM   #1
Just a DIY guy
bath fan and light wired together - any issue?
I bought a combo bath fan/light/nightlight (NuTone QTN110LE).
Although the wiring diagram shows each circuit (fan/light/nightlight) wired separately to independent switches, I wired up the lights (two 18 watt fluorescent) together with the fan (33.5 watts), with a single 14 gauge wire to a single switch. (I joined the fan and light wires together in the fan housing and connected them in a single wire nut to the hot lead from the switch, same with the neutral, and all the grounds (fan/light/nightlight) together).
(I'll run the nightlight separately to an occupancy switch when I get time).
The fan and lights work fine. But I just thought I'd ask the experts here if there are any issues with doing that.
Here's the install guide
http://www.nutone.com/PDF/InstallGui..._99044678B.pdf
M3 Pete is offline   Reply With Quote
Old 03-02-2012, 07:38 PM   #2
Electrical Contractor
kbsparky's Avatar
No problem-o. You can wire the entire thing to one switch if you so desire.
-KB
Old 03-02-2012, 07:39 PM   #3
Master Electrician
Rewards Points: 3,864
No issue electrically.
brric is online now   Reply With Quote
Old 03-03-2012, 11:17 AM   #4
Rewards Points: 240
I see that done in small office installations around here all the time.
fa_f3_20 is offline   Reply With Quote
Old 03-03-2012, 02:54 PM   #5
Just a DIY guy
Thanks guys
