Old 03-19-2011, 10:09 AM   #1
Bath Fan/Light GFCI
I am rewiring our masterbath on one 20 Amp circuit. There will be noting besides this bathroom on this circuit.
I would like to install a combo bath fan/recessed can (Broan 744) over the shower. The light says that it us UL listed for use over showers if it is a GFCI protected circuit. Can I connect these lights to the load side of one of the GFCI outlets?
Thanks!
handyman923 is offline   Reply With Quote
Old 03-19-2011, 10:34 AM   #2
Electrician
SD515's Avatar
Bath Fan/Light GFCI
In the US you can. You mentioned 'one of the GFCI outlets'. If you have a single circuit in that bath, you can protect all the receptacles and the shower fan using just one GFCI receptacle, wired properly of course.
Kyle
Old 03-19-2011, 10:40 AM   #3
Bath Fan/Light GFCI
Thanks Kyle! Yes, I was going to have 1 GFCI outlet, and then the other outlets and the shower fan/light wired to the load side of the GFCI.
David
Bath wiring with gfci questions berk21 Electrical 9 04-28-2010 10:46 PM
gfci outlets in bath colosseo Electrical 10 04-29-2009 09:09 AM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 07:45 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 10:31 AM
