Bath Fan Advice - Electrical - DIY Chatroom Home Improvement Forum
Old 12-10-2012, 08:09 PM   #1
Bath Fan Advice
I have a new Panasonic Fan for the bath. Vent up through roof. Outside the bath a have a switch to turn the light on. Inside the bath I have a GFI near the sink (switch is almost directly across from outlet). The fan has 3 wires. 1. Fan
2. Light
3. Night Light (don't think I will use)
I have access from attic. I have two blacks/two whites/ground and a red that was capped off and just sitting capped when I took off the existing light. Those all fed into the old light.
Not sure what to do with the red.
coopns is offline   Reply With Quote
Old 12-10-2012, 08:31 PM   #2
Licensed electrician
Rewards Points: 1,272
The red may have been a separately switched hot.
The splices should be in an accessible junction box.
The white should not be spliced to the ground.
Advice needed for installing full bath benb Carpentry 3 11-30-2011 10:03 AM
Bath Fan Wiring into Existing Bath Light? DIY?... timstahl87 Electrical 3 04-13-2011 11:33 AM
wiring half bath vs full bath hryser Electrical 1 03-08-2011 10:25 AM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 11:49 AM
Shattered glass down my bath drain! gudgebum Plumbing 3 01-08-2010 01:52 PM
