Basic Wiring Question When Changing Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 09:30 PM   #1
Basic wiring question when changing light fixture
I am in the process of changing my vanity light. I have taken the old fixture off and have a black, white and copper wire coming out from the wall. My new light has the same (black, white and copper) There is also a ground screw on the fixture. My question is this. I know I need to pigtail and wire nut each wire. When I pigtail the two copper (ground) wires do I have to use the ground screw as well or can I ignore it?
diydan is offline   Reply With Quote
Old 10-17-2011, 10:28 PM   #2
Yes use the ground screw
jmans8666 is offline   Reply With Quote
Old 10-18-2011, 05:49 AM   #3
Thanks, so what's the best way to do it. Do I wrap the fixture's copper wire around the ground screw and tighten and then pigtail and wirenut the remaining portion with the copper wire coming out of the wall?
Thanks again
Old 10-18-2011, 06:29 AM   #4
Rewards Points: 1,538
If the ground wire from the fixture is bare and long enough then you can wrap the middle around the ground screw and wire nut the free end to the ground wire in the box. (Or if the ground wire accompanying the power feed into the box is long enough you can wrap the middle ...)
In this situation, extra lengths of wire (pigtails) are not needed unless the existing wires don't reach.
AllanJ is online now   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
light switch wiring question. dannat Electrical 4 05-05-2011 09:11 AM
New outdoor light fixture compatibility with existing wiring fixitmama Electrical 1 04-17-2011 08:56 PM
basic light fixture connecting Nancychef1 Electrical 1 09-27-2010 12:07 PM
Wiring a new light fixture to old wiring! Carroll333 Electrical 1 07-28-2010 11:30 AM
