Basic Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2009, 10:05 PM   #1
Basic wiring question
I will be wiring a ganged switch box which will connect 4 black wires and 2 pigtails using #14 wire.
Is it better to connect all 6 wires in one wire nut or create 2 bundles with 2 wire nuts connected by a jumper?
If one wire nut, which wire nut is recommended for 6 #14 wires?
Rbutch is offline   Reply With Quote
Old 05-26-2009, 10:16 PM   #2
Electrician
Rewards Points: 778
Do all 6 into one joint. To make it easier strip a good amount of copper, line up the jackets of each conductor and slowly twist with your linesman. It may not hurt to try it on some scrap wire before doing the real thing. You could get away with a red marrette(#35 i beleive). Twist it on hand tight and then tighten it down with your linesman.
darren is offline   Reply With Quote
Old 05-26-2009, 10:19 PM   #3
300zx's Avatar
Post
Red one should do fine
300zx is offline   Reply With Quote
Old 05-27-2009, 04:11 AM   #4
" Euro " electrician
frenchelectrican's Avatar
The red wirenut is pretty close to the limit normally I will just grab the grey one { little larger than the red one but not that big as monster bleu one is } that will work perfect for ya.
Merci,Marc
Old 05-27-2009, 06:36 AM   #5
thank you for your help
Thermostat wiring question beer_geek HVAC 7 05-10-2009 07:49 PM
Basic wood cutting question sharding Carpentry 4 08-02-2008 05:56 PM
exhaust fan wiring question (aluminum wire) sflamedic Electrical 6 01-14-2008 05:41 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
